weird vaccum sound and bogging engine during acceleration?
i have another one guys!
this only happens sometimes but quite frequent.after start up and take off......when accelerating i hear what sounds to be a vaccum issue.when the hissing sound occurs the engine will bog down wich i then loose power......if i accelerate hard it will go away.if i hold acceleratoin at a steady slow speed it will continue to occur untill i throttle hard.seems like once it is up to operating temp,it will slowly go away and acceleration is normal?? this may have something to do with the shifting problem i just posted?? thanks again.you are all very intelligent people!!
on
literally unhook it and forget it. its only task in life it to help the engine warm up faster and I don't believe it does that one bit. Some just put it on a manual switch which is a good option if you still want to use. I think its a safety concern to have it hooked. If you ever try to get into traffic fast and that baby closes it pretty much like a stalled truck in the train tracks. Not good!
ok well if you don't mind i might see if i can make it up so we can wire up the ebpv on a switch. i'm not sure now though because i'm supposed to go out with this girl tonight. i'll call your house if i can to see what your plans are. what do you mean by it sounds like a turbine? kinda like a jet? and i'll be off in 8 min cause thats when class ends so i'll catch up with ya later.
