Taking out '04 F150 factory stereo
Old 03-13-2008, 04:48 PM
Wr3ckin_Cr3w's Avatar
Wr3ckin_Cr3w
Wr3ckin_Cr3w is offline
Ive looked up how to take the factory stereos on the web and they all point to how easy it should be for you to snap off the center console out, but mine isnt. Plus, I do not have the center shift as the one all the diagrams display. Can I pull the front center console off like the ones in here?
https://www.ford-trucks.com/article/...50_Trucks.html
Old 03-13-2008, 09:35 PM
soxfan81's Avatar
soxfan81
soxfan81 is offline
It just pulls out you can start at the top or bottom (just above the pull out cup holder). takes me about 5 secs to take out the console. I have column shifter.
Old 03-17-2008, 01:51 PM
AceSC's Avatar
AceSC
AceSC is offline
Sometimes those clips from the plastic surround can be tough, I know mine were. I started from the top with my finger tips and slowly worked my way down. I didn't use any screwdrivers because I didn't want to scratch any part of the plastic. After I took out the platic surround I squeezed each one of the clips a bit so that they would not be so tough next time around if I ever have to get access again. After you get the plastic off you will need to disconnect a few wire connectors that are atttached to the plastic surround. The air bag light is connected to the top part, and there are 2-3 additional cliped to the bottom. Once you do complete that you only have to unbolt the 4 fasteners that are holding the head unit.
Old 04-02-2008, 09:46 PM
rambunctious's Avatar
rambunctious
rambunctious is offline
open the ashtray and start at the bottom with a quick two handed tug
then pull in the middle,
then at the top
remove the wire to the airbag warninglight at the top of the bezel you jsut removed, then you can move it out of the way enought to get the radio out ( some wires will still be attached to bezel)
Ramb
Old 04-02-2008, 10:33 PM
deisele75's Avatar
deisele75
deisele75 is offline
If you need to use a screw driver, wrap it with electrical tape so it doesn't scratch anything.
slim813
1999 to 2016 Super Duty
08-31-2016 03:04 PM
changoo
2009 - 2014 F150
12-02-2010 07:29 AM
v8xploder
1978 - 1996 Big Bronco
07-27-2010 09:41 PM
tkc42
2009 - 2014 F150
02-07-2010 02:42 PM
gui88ford
2004 - 2008 F150
12-31-2008 11:50 AM
Quick Reply: Taking out '04 F150 factory stereo
