1979 F350 4x4 dually - Ford Truck Enthusiasts Forums
Old 03-13-2008, 04:47 PM
krol's Avatar
krol krol is offline
krol is starting off with a positive reputation.
I can pick this truck up for relatively cheap, but I wanted to know what axles are in it. Did these come with a D60 in the front and is it a 9" in the rear? Thanks for your help. It's got a 400 and 4spd, cab and chassis. Once again, 1979 F350 4x4 dually.
Old 03-13-2008, 05:27 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Should be Dana 70 rear and Dana 60 front
No Ford PU with box had dual -wheels
Only Chassis cabs had duals
So this truck has been made up.
Old 03-13-2008, 06:29 PM
krol's Avatar
I did mention in my post that it is a cab and chassis. Mil1ion, by made up did you mean it was put together or did you mean it is a figment of my imagination?
Old 03-13-2008, 06:48 PM
My apology's for the terminology, I am usually more careful than that
It was built/made that way, by someone because Ford didn't build dually trucks with PU boxes.
Old 03-13-2008, 08:14 PM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.RCrawler is gaining momentum as a positive member of FTE.
I also don't think there was a Ford built DRW 4wd's before the mid 80's.
Jason
Old 03-13-2008, 08:43 PM
krol's Avatar
Thanks Mil1ion, I was just kidding around about the imagination part, I was pretty sure I knew what you were getting at. There's no box on it, the cab and front clip look pretty good. We'll see how this goes.
Old 03-13-2008, 09:18 PM
Naked_Farmer's Avatar
Naked_Farmer Naked_Farmer is offline
Naked_Farmer is starting off with a positive reputation.
They did make 4x4 cab and chassis in dually though right? A buddy of mine has a 79 f350, 4x4, dually with a 9 ft dump and it looks factory to me cept the 460.
Old 03-13-2008, 09:38 PM
Yes, Just think about all those F350 Cube trucks you see.
Cab & Chassis to put whatever you want on the chassis.
Firetruck bed, Service truck bed,etc
Old 03-13-2008, 09:46 PM
I know what ya mean but I dont see any 70's eras around here though.
Old 03-14-2008, 12:14 AM
tylstruck tylstruck is offline
tylstruck is starting off with a positive reputation.
Wow, Dennis, I did not know they didn't produce any exended box duallies. Pretty rare as i think we all remeber that brown one on ebay months ago. Probably still there.
4X4 duallie is pretty rare too. Must be DSO spec. Wouldnm't be complex to put a 4x4 on a dually. Lots of 4x4 one ton trucks with singe rear wheels.
Tyl
Old 03-14-2008, 12:21 AM
Old 03-14-2008, 03:57 AM
f250rangerexplorer's Avatar
f250rangerexplorer f250rangerexplorer is offline
f250rangerexplorer is gaining momentum as a positive member of FTE.
as far as i knew the duallies didn't even come in a 4x4 until 1982 or something like that. I knew that there was a F-350 4x4 in '79 but not a F-350 4x4 in '79. There wan't a factory box option until 80 for duallies.
Old 03-14-2008, 06:27 AM
Gregg C. Gregg C. is offline
Gregg C. is starting off with a positive reputation.
I was also under the impression there were no factory 4x4 duallies until the '80's.
I would love to see the vin and the door tags from this truck!
Old 05-01-2013, 09:26 PM
lchapelle lchapelle is offline
lchapelle is starting off with a positive reputation.
I also have a 1979 f350 dually 4x4 but the 4x4 was added. I bought this recently to haul and dump wood on my property but now the pto pump leaks so bad I cant raise the bed. trying to get some info on fixing the pump.
Old 05-02-2013, 01:55 AM
privateer, eh's Avatar
privateer, eh privateer, eh is online now
Danger City Kitty
privateer, eh has much to be proud ofprivateer, eh has much to be proud ofprivateer, eh has much to be proud ofprivateer, eh has much to be proud ofprivateer, eh has much to be proud ofprivateer, eh has much to be proud ofprivateer, eh has much to be proud ofprivateer, eh has much to be proud ofprivateer, eh has much to be proud ofprivateer, eh has much to be proud of
in the future, look at the date on the post's your replying to. Dont feel foolish as a lot of people have made the same mistake. Enjoy the forums and ask away, check out some of the other forums on the list. you'll be amazed at what you find.
1979 F350 4x4 Creger camper. BearWallow 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-10-2014 03:09 PM
1977 F-350 2WD body swap with 1979 F-250 4WD retiredsquid 1973 - 1979 F-100 & Larger F-Series Trucks 0 06-23-2013 11:41 AM
Converting a 1979 F250 to use dually hub centered rims on the front Malahki 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-08-2011 12:33 PM
1979 f250 4x4 vs 1979 f350 4x4 frame... highway90 1973 - 1979 F-100 & Larger F-Series Trucks 47 12-08-2010 07:36 PM
78 79 f350 dually 4x4 ozzy460 1973 - 1979 F-100 & Larger F-Series Trucks 17 09-27-2004 11:32 PM
Tags
1971, 1979, 350, 4x4, 79f3504x4dually, aloha, complete, dually, ebay, f350, ford, nm, parts, rare, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
