Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 03-13-2008, 03:16 PM
strokersace's Avatar
strokersace strokersace is offline
Garage is empty, add now
strokersace has a very good reputation on FTE.strokersace has a very good reputation on FTE.strokersace has a very good reputation on FTE.
"How To" High Idle Mod with Upfitter Switches
Here's how I did it:
SUPPLIES:
05 Upfitter Switches & Harness: powerstrokeshop.com
Single Pole Single Throw Toggle Switch for testing: RadioShack
10K Linear Taper Potentiomenter: RadioShack
Knob for pot: RadioShack
2 Auto Relays (30/40 amp with 5 terminals) plus pigtails: Local automotive electirical shop
18 gauge Wire
Solder & Soldering Gun
Wire Crimpers/strippers
Wire ties
Butt Connectors
End Connectors: Male/Female
Parallel Tap Connectors: Male/Female
Heatshrink & Heatgun
*Hook it up temporary on the floor to make sure it works before permanent install. If there are any hang ups, you'll figure them out beforehand. Did this on my 02 F350, so I believe that the wire colors will be the same for all 99-03 powerstrokes. Huge thanks to cef2lion for help on upfitters! High Idle Mod was tweaked from a write-up by Sparky called "AIC MOD".*
STEP 1: Installing Upfitter Switches
1.Remove radio & large cover across dash, glove box, & lower center section (where trash hook & cupholders are). I replaced this section with an 05 panel. You will have to trim the dash a little for a proper fit. If keeping original, refer to rwilimo's write-up to modify it for upfitters.
2.Upfitter relays mount above glove box on pass. side. One hole will have to be drilled in the metal framework.
3.Run harness across dash towards main fuse box connecting ground as you go.
4.Locate white connector with 2 wires (grn/org & org) on the back of the fuse box that matches the upfitter. Unplug & remove both pins. Remember which slots they came from.
5.Remove ltblue/rd (illumination) and vlt/org (power) pins from upfitter connector & transfer 2 factory wire into original locations. Plug connector back in.
6.Tap the illumination wire into same color behind headlight switch by extending it. Extend power wire and connect to Customer Access Wire or CAW (wht/ltblue blunt wire in middle of dash by the blinker relay).
7.Turn key on & test switches & blunt wires for power. Light on switches should come on & blunt wires should have power when up. Turn on dash lights to make sure illumination is working. On powerstrokes, all fuses should be in box already.
STEP 2: Toggle Switch
1.Tap into wht/ltblue CAW & run a wire to 1 side of the switch. From the other side of the switch, run a wire to the same coil terminal of both relays. From the other coil terminals on both relays, run a wire to the parking brake wire (ltgrn/rd) & tap into it.
STEP 3: Throttle Position Sensor (TPS)
1.Look at the pedal & you'll see a plug with 5 wires going to it (red/green, red/yellow, brown/white, grey/white, & yellow/white). The ylw/wht wire WILL NOT be used. Carefully untape them so you have 6-8 inches to work with. Disconnect the plug from the TPS.
2.Cut RED/YELLOW wire 3-4" from plug & install end connectors on both ends. Ran a wire from wire bundle side to the common term of 1st relay. Run a wire from the plug side to the Normally Closed (NC) term of same relay.
3.Run a wire from the Normally Open (NO) term on same relay & tap into the RED/GREEN wire by the TPS plug.
*This will use all the terminals on the 1st relay.*
STEP 4: 2nd Relay & the Other Wires
1.Cut BROWN/WHITE wire 3-4" from plug & install end connectors on both ends. Run a wire from bundle side to the common of the 2nd relay. Run a wire from the plug side to the (NC) of the relay.
2.Run a wire from the (NO) of the relay & connect it to the left term on the POT (looking from shaft side with terminals down. Writing should be right-side-up if there is any).
3.Run a wire from the center term of the POT & tap into the GREY/WHITE wire by the TPS plug.
*DO NOT solder wires to pot until you know it works!*
4.Make sure bare connections are not touching & reinstall TPS plug.
STEP 5: Test & Permanent Install
1.Start vehicle & idle normally for 30 sec to 1 min.
2.Set parking brake and flip toggle switch to on. If motor rev's high, turn shaft on POT in other direction to lower. If RPM's don't change, turn shaft other way & they should rise. If nothing changes RPM, then check all connections. If RPM's stay too high, then you'll need a 50K POT as there's not enough resistance.
3.I mounted the relays with an 'L' bracket next to the main fusebox on the lower metal dash support with an existing hole.
4.Wanted #4 of upfitters to run mod, so I unplugged the white connector from fusebox & removed the corresponding pin for #4 (SOLID RED wire). The blunt wire for #4 is ORANGE/LTBLUE on the upfitter harness. Hook these 2 wires up just like they are terminals on the SPST toggle.
5.Mounted the POT upside down in same metal support as relays on the far right side using an existing hole. Soldered wires onto it before putting in place. Installed **** on shaft for adjusting. I can reach down & adjust it to a desired RPM without anyone ever seeing it. I heatshrinked all connections as I went.
FINALLY: Once everything is tied up out of the way and mounted, start vehicle & test again. Should work just like before. Reinstall all dash panels removed earlier & ENJOY!
*I used wiring diagrams for both my 02 & the upfitters. Helped a ton! Still have them if anyone needs them.*
It is long & detailed, but hopefully it helps someone looking to do these 2 mods together with limited or no experience. It makes for a very clean install without using any aftermarket toggle switches.
If someone can help me figure out how to add pics into this post, I'll redo it. Otherwise they'll be in my gallery tonight.
  #2 (permalink)
Old 03-13-2008, 04:34 PM
bdrummonds's Avatar
bdrummonds bdrummonds is offline
1999 Ford F-250
bdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud of
Very nice write up. Rep points to you.
__________________
Brandon
PAA MEMBER # 7.3, 99.5 CC,4X4,SB, leveled,live tuned by Jody,1.15 van turbo w ATS housing,6.0 IC,AFE big boost filter, Petes Armour,fuel bowl delete,black MBRP stacks, 02 headlights,F650 dash, 16x10 MT wheels, 35" tires,and a bunch other stuff that wont fit in my sig. 322K and counting.
  #3 (permalink)
Old 03-13-2008, 06:31 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Great job with the instructions. Can you post any pictures? I love pictures. Also if you have a scanner you can scan the wiring diagram into a pdf format and attach it to this post so when we all bookmark it we have everything we need.
Apparently you're one of the few people I'm allowed to spread the reps around to so they've been given.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 435,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #4 (permalink)
Old 03-13-2008, 06:33 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32 weekendwarriorfsw32 is offline
Master of Strokes
2004 Ford Excursion
My Garage
weekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud of
Good post
__________________
Nick PAA#9
08 F-450 KR 6.4 Elite Race Trans, Elite 71mm turbo, ARP, RDP I/C Boots, 5.5 Icon lift, 22.5 AF Independence wheels, OUO
04 X 6.0 Powermax, ARP studs, MBRP, RDP I/C boots, SCT with Inovative, 14.0@96.4MPH
01 X 7.3, Dp, Cass 238/80 Hybrids, Terminator Dual pumps, TNBB, TE thermostat, ARP studs, Fluidampner, RDP 6637, RDP boots *** Big Thanks To RiffRaff Diesel Performance ***
  #5 (permalink)
Old 03-13-2008, 07:17 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
Quote:
Ditto. Nicely done.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
  #6 (permalink)
Old 03-13-2008, 11:20 PM
Thanks guys!! It took a while to figure out with alot of trial and error, but it finally came together.
As far as attaching a pdf file to the post, I'm not sure how to do that. It says that I "may not" post attachments down at the bottom of this thread page. I'm guessing that goes along with pictures as well. Can you guys help with this so I can add them into the post?
Thanks,
Strokersace
__________________
Ryan
97 F350 CC Dually psd auto; 38 gal rear tank, Electric fuel, AirDog, Hypermax I/C & Stage 2's, BTS HPOP, SD van turbo, Hydroboost, ARP's, 910's, SB pushrods, Swamps IDM, Tymar, Sound deadening on both sides of firewall, 6.0 trans cooler, SD tranny lines, SD engine compartment conversion, Gauges, HID's, other pretty stuff, ALOT of custom stuff - need BTS trans & bigger turbo
  #7 (permalink)
Old 03-14-2008, 12:21 AM
Finally got my pics into my gallery. Under upfitters.
Strokersace
__________________
Ryan
  #8 (permalink)
Old 03-15-2008, 09:21 AM
Quote:
Originally Posted by cookie88
Ditto. Nicely done.
Thanks Cookie!! Got a question... Would like to post pics directly on here, but I can't find the "Browse" button on the page nor will it let me to add attachments. I've posted everything in my gallery, but thought I'd add some on here. Any ideas on how to do this? Do I need to be a member of Club FTE?
Thanks,
Strokersace
__________________
Ryan
  #9 (permalink)
Old 03-15-2008, 09:32 AM
F350-6's Avatar
You mean like this?
Click the image to open in full size.
Make sure you're in the Go Advanced page or Preview Post page (not the quick reply) Then you can either scroll down below the box where you type and click on Manage Attachments. A new window pops up with the browse button to attach photos out of your computer, or what I did here is view your gallery in a different tab or window and right click on the picture and select copy image location (I use firefox browser for the spell check feature. IE may have different wording) Then when you get to the place you want to insert the picture click on Click the image to open in full size.at the top of the box you're typing in. If you hold your pointer over it, it says Insert Image. When you click a window pops up. Just paste the image location you copied from your gallery and hit ok.
I hope that made sense.
__________________
Chris
  #10 (permalink)
Old 03-17-2008, 11:25 PM
SUPPLIES:
18 gauge Wire
Wire ties
Butt Connectors
5.Remove ltblue/rd (illumination) and vlt/org (power) pins from upfitter connector & transfer 2 factory wire into original locations. Plug connector back in.Click the image to open in full size.
Will add pdf's of wiring diagrams.
-Ryan
  #11 (permalink)
Old 03-17-2008, 11:38 PM
Make sure you're in the Go Advanced page or Preview Post page (not the quick reply) Then you can either scroll down below the box where you type and click on Manage Attachments. A new window pops up with the browse button to attach photos out of your computer.
Chris- THANKS!!! For the help! I don't get this option in the advanced page or the preview post. It could be because I haven't got my membership yet. Absolutely no "manage attachments" below where you type.
I was, however, able to copy them from my user gallery and paste them into text, just as you did. Do you have any idea how to add in the pdf's of the diagrams? I tried opening them up using my internet browser and then adding the link to it, but couldn't get it to work. Any suggestion?
Thanks again!
Ryan
__________________
Ryan
  #12 (permalink)
Old 03-17-2008, 11:47 PM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
Tenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud of
Wow, nice writeup. Reps on the way. I think I will stick with the chip hi idle for now, but that is what I would do if I needed one. Great post.
__________________
Mike
2001 Auto Crew Cab 4X4. 38R and Swamps Hybrids. Transgo and diode Tranny. 400HP but not really. 05 front end and stickers makes it faster.
  #13 (permalink)
Old 03-18-2008, 12:08 AM
Quote:
THANKS!! Took some time but worked out exactly like I wanted it to. I hear ya on the chip high idle. I had a 4 position on my '95 with high idle and it was nice. But since I went with the Edge products with this '02 and still wanted the high idle, I opted for the dash panel replacement and the upfitters. I was happy with how clean it looks. Now all I have left to do is get it painted up to match the rest of the dash. Taking the truck by the paint place on Wed. to get it matched.
Ryan
__________________
Ryan
Tags
2005, 64, 73, access, customer, excursion, fast, ford, high, idle, mod, powerstroke, switches, upfitter, upfitters, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
