Making and f-1 4x4 - Page 5 - Ford Truck Enthusiasts Forums
Making and f-1 4x4
  #61
Old 01-11-2010, 06:49 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Fantastic!
This is such a great truck, thanks for all the updates and the pics.
Bobby
  #62
Old 01-12-2010, 10:20 AM
telefunkken telefunkken is offline
telefunkken is starting off with a positive reputation.
real nice job on the F-1,a while back i was transporting a mack tandem from harrisburg to uniontown , took the senic route was a little east of somerset saw a junkyard (neppers) i think any old trucks in there?
  #63
Old 08-21-2010, 03:14 AM
79 f-150 guy's Avatar
79 f-150 guy 79 f-150 guy is offline
79 f-150 guy is starting off with a positive reputation.
i just found this... i think you inspired my next project, it is so neat. i just love your truck.
one question i have is, did you measure an old jeep to see if that rear would work in the front? i can get a good running mid 70's cj7 for 450.00 and that has good rears, t-case and a solid running amc 6-cylinder in it.. i think it would fit the bill for a parts rig, but i'm just ponderin idea's here..
  #64
Old 08-21-2010, 09:41 AM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
Dana 44's are built for the front with reverse cut gears, so putting a rear in the front won't work, plus there needs to be provisions for steering knuckles to mount, and the differential has to be offset enough to line up with the tcase. Unless I understood your post wrong? Now, a complete quadratrac from a 70's cherokee on the other hand, would be an interesting swap.
I've been tossing the 4x4 idea around myself, as I have more than enough 4x4 parts laying around. I'm working out the details currently. I would use my other F1 frame, if it wasn't so rusted.
  #65
Old 08-21-2010, 11:08 AM
jpb222 jpb222 is offline
jpb222 is starting off with a positive reputation.
I am not sure if the cj's track width in the front will work it may be a tad narrow. Also it is a passenger side drop BUT if you use the jeep or a chevy t-case you will be fine. however I am pretty sure that the rear axle is too narrow.. you will have to use a different axle in the rear.
  #66
Old 08-21-2010, 11:29 AM
huh, id have to look more into it.. i was thinking of using the front rear from the jeep and using the amc 6-cylinder, tranny and t-case and using a ford rear rear.. i was also thinking the jeep cj-7 steering box would be nice to add on with a custom steering shaft and power steering.
but i dont know, the bronco front rear worked great in you aplication but i would want to avoid cutting the endes off the rear and swaping on gm ends becouse i've never modified a rear before other than changing perches.
  #67
Old 08-21-2010, 11:32 AM
havi's Avatar
I get it now. Rear=axle.
  #68
Old 08-21-2010, 11:57 AM
I didn't cut the ends off the axle. I just BOLTED the GM knucle to the FORD inner "c"
  #69
Old 08-21-2010, 12:28 PM
ow, i thought you ment you changed the ends.. so thats an unmodified bronco rear, eccept for chaging the perches and spindals.
also what was the t-case and tranny from.. a small bronco aswell??
  #70
Old 08-21-2010, 01:27 PM
yup I just cut off the coil spring wedges and welded on leaf spring perches. the housing is otherwise a stock EB housing.
the tranny and t-case came from the same 1970 bronco that I took the axle from....
  #71
Old 03-23-2011, 02:11 PM
I haven't posted in a while..... figured I would.
I am now just shy of the 50,000 mile mark on the truck. I finally had a break....the clutch hub busted in the limited slip and my rear started acting like an open diff.... I pulled it apart put a new hub in it and new clutches and all is good again.
the winters have been a little rough on the truck and I need to do some metal repair in the future and want to re-paint it before next winter (the same paint scheme).
I finally got around to putting all 1950's rims on it to give it a more authentic look.
I really would like to find a repairable bed that I can work on and get ready to just swap over on a weeknight since I use this truck EVERY weekend to haul my band equipment to shows.. I guess if worse comes to worse I can just swap the canopy over to the "sleeper" for a week or 2......so if anyone knows of a repairable 48-50 bed box in my price range (cheap) let me know!!!!
laitly I have been busy restoring other peoples cars for $$ but I did pick up parts and a title for a 1931 ford model a pickup...so I am going build one of those next, concurrently with my 1930 hot rod coupe.
  #72
Old 11-21-2011, 10:07 AM
Well I ended up building a nice bed for my black truck. I still need to find a nicer tailgate for it or buy a new one before I paint it.. I plan on painting it gloss black next summer if time permits.
And then used the old bed of the black truck with some additional patching to build a better bed for the green truck. I also changed out the hood with a less rusty one, replaced the canvas and repaired a few other odds and ends on the green truck before winter.
I got some more done on my other projects too and got started on my NEXT ford truck.
  #73
Old 11-21-2011, 11:55 AM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
I can't believe I missed this build until now. Great Job you are doing.
  #74
Old 11-21-2011, 12:56 PM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
I also just read this thread for the first time and it is amazing! A budget 4X4 build!! Too bad you live in the rust belt.
  #75
Old 11-23-2011, 10:05 PM
thundersnow70's Avatar
thundersnow70 thundersnow70 is offline
thundersnow70 is starting off with a positive reputation.
WOW, what a great truck! love the od green and flat black. i have read the thread twice and am still trying to figure out what all the parts are. someone tell me if i am right or wrong. 48-50 cab, 48-50 box, 51-52 front clip and hood? Plus, i wanted to get this back on page one so more people could find it. i am seriously thinking about cutting the frame on the f2 MH and running the bed off the pos 48. the frame on the duece has already been broken and welded back together so whats the harm. i'm gonna run the ndt gravedigger tires to. the biggest 16in. coker sells. man i bet i would get some hate mail for that. it would look wicked though, a darkside 52 MH shortbox with a 254 flathead 6.
Project: Smogie...RacinNdrummins IDI build RacinNdrummin Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2185 10-22-2016 11:22 PM
LFD's T-Bird IRS install How-To Rokcrln 1948 - 1956 F1, F100 & Larger F-Series Trucks 56 08-07-2016 05:24 PM
I finnaly found a good start to a nice bronco jpb222 1966 - 1977 Early Broncos 18 12-12-2014 10:29 AM
Finally purchased the king ranch and unloaded the lariat MrAgent007 1999 to 2016 Super Duty 61 04-06-2014 08:38 PM
intercooler all done, final product pics rideracelivemx7 1994.5 - 1997 7.3L Power Stroke Diesel 35 06-04-2010 11:34 AM
Tags
1956, 4x4, 79, box, caster, f100, f150, f350, f4, f600, ford, goofy, junkyard, making, parts, rains, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
