Just installed the Edge Juice Platinum with the attitude monitor in my truck.
Contrary to a lot of the postings on here, the new PLATINUM edition does take the transmission into account, allowing the user to adjust defueling percentages when shifting to each gear as well as firm shift points. There is also torque converter settings and transmission slip protection settings built into it.
The amount of power this programmer puts out is awesome, and it seems like the people that end up having transmission problems / engine problems are probably pushing too hard or running it on the extreme setting, which is not recommended for stock or even just slightly modified trucks.
I have the pillar mount for the attitude monitor which is very clean and professional looking.
Reading the manual is a big help and gets you to understand the do's and dont's of this programmer.
Definitely recommend it to anyone else that has a 6.0
Also, this chip has a mileage setting that increased my MPG from 13.8 to 18 on the highway!
__________________
2007 F250 6.0 PSD CC Lariat
4.5" Donahoe Racing Lift Kit
DirtLogic Steering Stabilizer
20x10 KMC Diesel Wheels
35x12.5 Toyo MTs
4" Magnaflow SS Turbo-back exhaust
EDGE Juice Platinum w/ Attitude
Yes, hand calculated. I have only had it a few weeks, so I will continue to take some data, but it has made a huge difference. This programmer allows you to shift on the fly, so that once you get up to speed on the highway, you put it in mileage mode and it just trickles in the fuel. Granted if you step on the throttle it doesnt respond well, but if you need to take off just put it back on one of the other modes
__________________
35x12.5 Toyo MTs
I also run the exact module you do. I kept mine on the mileage setting and it definately did increase the mileage however I still buggared up my headgaskets.
__________________
'05' F350 Harley Crewcab
FS-2500 Oil Filtration System
AFE Cold Air Intake
Edge Juice Attitude Platinum
MBRP Dual 4" Exhaust
Herd Front Bumper
Dual 10" Lightforce Lights
Espar Diesel Pre Heater
Smoked Recon Tail & Cab Lights
The reason for my headstuds is the Edge blew my headgaskets. I did seem to get better mpgs with the edge. I only had it for 2 weeks though before I took it off.
__________________
2005 F250 KR CC 6.0L
DashDAQ - soon to be Phalanx Monitor
ARP headstuds
Silverline Turboback
SCT X3...Spartan and Innovative tunes
DFuser Coolant Filter
aaa i don't know about mine yet.. I have had it a week and cant seem to find all the settings that make the trany shift like i want... it is eather to soft the front end of the truck falls in acceleration or to firm it jars me when it shifts.. What do you guys have the trany settings set on??
Trans mod recommended comes up when you make ANY tranny setting adjustment. I would recommend putting your defueling percentage up a little higher (Im running at 60%) The shifts are firm, but not too agressive. Keep in mind, stock is 100% defueling I believe....so bringing it down to 0% I would say is a little dangerous. What your doing is not taking any engine torque and power away from the tranny when it is shifting, therefore really "Slamming" the clutch plates and forcing the tranny into gear versus letting to fall into gear like it should. Keeping some fuel getting brought into the engine during the shift is ok, but the way I understand it, 0% is probably not a good way to run
__________________
35x12.5 Toyo MTs
i had the edge for about 30k miles and i kept mine on 100% defuel....sure it sacrifices a little power and doesn't shift as quick, but unlike many my tranny is still working fine.
__________________
2003 F250 6.0 PSD SB Lariat 4x4 4" superlift, 35 x 12.5 x 20 Toyo Open Country MTs on 20 x 10 American Racing - Chrome Cannons, Volant Ram Air Intake, Silverline 4" Turbo Back Exhaust, SCT tuned by SDT, ARP Head Studs, ISSPRO Gauges - Pyro, Trans, and Boost, Air Dog 100, ITP Reg. Return
When you say "buggard up" did you have to replace them?
Yes they had to be replaced and depending on how ignorant the dealer is they CAN make you foot the bill. In Canada that bill is anywhere from $4000-$6000 depending on wether the dealership does the repair or not. A lot of the guys on here hate the Edge system but I have not had any tranny issues and as for the headgaskets... Ford has admitted they are a common problem for the 6.0. From what I understand the gasket issue can be fixed with ARP headstuds instead of the factory headbolts. Hope this helps ya out.
__________________
AFE Cold Air Intake
Herd Front Bumper
Yup you said it! I left mine at 100% as well and I have not had a single problem yet with the tranny (53,000km to date). I checked my 1/4 mile time on the module and it still says 15.8sec (that was a run on level 5) even with the sloppy tranny shifting but I don't think the time is too accurate.
__________________
AFE Cold Air Intake
Herd Front Bumper
