Rear End Replacement or Rebuild - Ford Truck Enthusiasts Forums
Old 03-13-2008, 01:14 AM
imjustagirl imjustagirl is offline
imjustagirl is starting off with a positive reputation.
I am wondering if anyone here knows approx how much it would cost to have the rear end of my '05 f-150 rebuilt or replaced. I just bought it and it is howling very loudly - I know it needs to be done asap. I am also thinking of looking into a pick and pull and swapping one out.
Also how hard/easy would it be to upgrade from the 8.8/3.55 to the 9.75/3.55?
thanks!
Old 03-13-2008, 06:10 AM
wlgoble's Avatar
wlgoble wlgoble is offline
wlgoble is starting off with a positive reputation.
I just had the clutch packs replaced in mine and it cost 980$ at the Ford dealer. My extended warranty paid for it. Dont know if clutch pack would cause a howling though, maybe gears. Anyway I dont see a gear swap being any cheaper. Of course if you go anywhere but the Ford dealer, im sure you can save some money. Good luck !
Old 03-13-2008, 09:52 AM
dartguy699 dartguy699 is offline
dartguy699 is starting off with a positive reputation.
if you just bought it you should approach the dealer that you bought it from for some assistance. even if there is no warranty usually you can get some help especially if you talk nice to them.
jim
Old 03-13-2008, 12:18 PM
Twinsdad98 Twinsdad98 is offline
Twinsdad98 is starting off with a positive reputation.
Clutch packs are for the shudder issues. To swap from a 8.8 to 9.75, you'll have to get a new rear end. The change is fairly easy and maybe cheaper than rebuilding your current pig. Maybe find an axle at a junk yard. When you have it installed, drop the cover, check the pattern and put fresh lube in it. If the axle is just whining from the gears, not really a durability issue, more just a huge annoyance.
Old 03-13-2008, 06:57 PM
osbornk osbornk is offline
osbornk is gaining momentum as a positive member of FTE.osbornk is gaining momentum as a positive member of FTE.
A friend of mine rebuilt a wreck a couple of years ago and paid $700-$750 for a 9.75 LS differential complete from a low mileage wreck.
Old 03-14-2008, 01:02 AM
So right now I have the 8.8/3.55 and have decided that swaping out the old for a 9.75 with 3.23 is my best option. I found one online for $1000 and I will just do the labor myself. My question is - does the e-brake hookup the same way from the old to the new? Also are all of the sensors the same (ABS, etc.)? Thanks
Old 03-14-2008, 01:11 AM
i got a price quote for $1700 to fix the 8.8 . i knew it was broke but the truck was cheap.it is cheaper to by the 9.75 if it will bult right in. i do know i will have to shorten the drive shaft thank for the help
Old 03-14-2008, 01:26 AM
STRK BY STRK BY is offline
STRK BY is starting off with a positive reputation.
Search the TSB, There is one that addresses the howl and is covered under warranty, just had mine replaced under warranty for this issue.
They supply all new gears and bearings and switch the lube to 70/140...
Old 03-14-2008, 01:57 AM
the truck has 150000 ford will not help me it the hole rear end. the ring and p and both axels are pist .looking for a cheap fix. thanks for any help you can give.
Old 03-15-2008, 03:22 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
http://www.newtakeoff.com/index.asp?...OD&ProdID=8249
check this out.....they sponser this site as well i believe...
Old 03-15-2008, 03:34 PM
dont forget about the anti lock sensors and e brake hookups between the different rear ends-they may not be compatible. i would think a used 8.8 with 3.73 would be the way to go. far easier to change and not much more $$$ than trying to adapt a diffferent style.
jim
Old 03-16-2008, 12:13 AM
i bought the one from new take offs . cost 1061.00 ship and tax.ca sucks.
Old 05-11-2008, 02:17 AM
So I got the rear end, pulled everything apart and put back together with only a few minor hiccups. The drive shaft's ujoints were non removable; so the drive line shop locally said to build a new one would be 600 bucks, so I found a local wrecking yard with one and did that for 1$50 instead from a wrecked truck w/ 9.75 rear. Gone 6,000 miles so far and need to balance the drive shaft, but other than that it was a very easy installation and good deal.
Old 05-11-2008, 04:28 AM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
good to hear...people always think I'm crazy when I get stuff from a junkyard. but I believe there is nothing wrong with re-using parts...especially if it's cheaper.
did you swap to a 9.75, or just keep the 8.8?
if you upgraded, what all did you need to switch? or was it just a simple unbolt and rebolt new one?
Old 05-13-2008, 12:50 AM
it was a unbolt and rebolt 3hr to do it was easy. me and my dad
ranger rear end widths wildstang Ranger & B-Series 15 05-17-2015 08:28 AM
VIN Decode/ Number Dummy HELP! thorswhisper 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 05-04-2015 01:02 AM
can I convert my D60 from 8 lug to 5 on 5.5? dirtydeeds 1973 - 1979 F-100 & Larger F-Series Trucks 20 01-17-2015 09:28 AM
ford 8.8 open rear end hard to change to lsd Jason302 1987 - 1996 F150 & Larger F-Series Trucks 2 07-20-2011 08:24 PM
3.08 to 3.55 gear ratio FordDrvr Clutch, Transmission, Differential, Axle & Transfer Case 21 07-23-2003 12:30 AM
Tags
2001, 88, 975, clutch, end, expedition, f150, ford, pack, packs, rear, rebuild, replacement, replacing, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
