Rear End Replacement or Rebuild
I would also add grease to the splines, since that's been an issue with some F150s. If you're rotating the shaft, might as well as some grease.
Did you match mount the d/s to the axle? There's a paint dot on the shafts that should be matched to the axle. (at least I think, I know we did this on Explorers)...
thorswhisper
05-04-2015 12:02 AM
dirtydeeds
20
01-17-2015 08:28 AM
Jason302
07-20-2011 07:24 PM
FordDrvr
21
07-22-2003 11:30 PM
