how much for new chipped key. - Ford Truck Enthusiasts Forums
Old 03-12-2008, 11:34 PM
mack150 mack150 is offline
mack150 is starting off with a positive reputation.
Unhappy how much for new chipped key.
i've got a 99 f150 and today i lost my keys.. the truck is sitting still.. anyone know how much to get a new chpped key made and how long it will take the dealership??? any help would be awesome.. thanks
Old 03-13-2008, 12:19 AM
fisher_of_man's Avatar
fisher_of_man fisher_of_man is offline
fisher_of_man is starting off with a positive reputation.
I know your in a hurry, but if you can wait or find someone on Ebay that would overnight a chipped key to you, you'd be better off. The dealership is going to charge you 4 or 5 times what you could get on on ebay for. Unfortunately, I'm not sure exactly what they'd charge you though. there are always some on Ebay. and you can find the procedure for "setting" the chipped key on here. Good luck!!
and welcome aboard...sorry it's under such cruddy circumstances!
Old 03-13-2008, 12:22 AM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
A good lock shop should have them for far less than a dealer but I am not sure if they can flash them without any old keys.
Old 03-13-2008, 01:44 AM
i appreciate your advice but there is one slight delima....i have to drive to jacksonville tomorrow for a flight out to colorado... soo i have to have my truck working asap
Old 03-13-2008, 07:06 AM
Ron W.'s Avatar
Ron W. Ron W. is offline
Ron W. is starting off with a positive reputation.
Quote:
Do you have a non chipped key so they can match the cuts or the key code for your truck, it would make the job much easier. If you have no key at all the key code will be needed (will be in the sales folder at the original selling dealer) or a locksmith will be needed to cut a key to match the existing tumbler(s). Most dealers Ive seen and or worked at seem to get between $25 and $35 dollars for the key itself but the key(s) will also need to be programed to your truck or it still won't start, that would also need to be paid for $50? Don't know what a locksmith would charge and don't know if they would have the equipment to program the key(s) for you.
Also be aware some vehicles need 2 keys to be programed when you have none rather than just one key. I would suggest getting two anyway and when you get the time/money have a third chipped key cut for you, once you have two that will allow the truck to start you can program a third or forth yourself saving the programming charge.
Good luck
Old 03-13-2008, 07:13 AM
Lariat02 Lariat02 is offline
Lariat02 is starting off with a positive reputation.
My local dealer (GA) wanted $65 for the chipped key and programing altogether, they also needed to see proof of ownership for the vehicle.
Old 03-13-2008, 07:18 AM
Ron W.'s Avatar
Quote:
Excellent point, I forgot to mention that proof of ownership is required by Ford if he takes it to a dealer.
Old 03-13-2008, 07:27 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Then you'd better get off the internet and get on the phone.
A good locksmith will be able to set you up, but, while less than a tow to a dealership, it won't be cheap.
Steve
Old 03-13-2008, 11:15 AM
TEKWS01 TEKWS01 is offline
TEKWS01 is starting off with a positive reputation.
Please correct me if I'm wrong. I was under the impression that if all keys are lost, you have to replace the pats (instrument cluster). is this correct or not correct?
Old 03-13-2008, 11:27 AM
Quote:
It is NOT correct.
You do, however, require the services of either a dealer or a well-equipped locksmith to reset and reprogram the anti-theft system and to produce at least two replacement keys.
With two valid PATS keys, you can then program additional cut PATS keys into the system using the procedure in the owner's manual.
Steve
Old 03-13-2008, 11:31 AM
Thanks Steve, That takes a load off my mind..
Old 03-13-2008, 08:49 PM
cbruns9 cbruns9 is offline
cbruns9 is starting off with a positive reputation.
I purchased my 2002 F150 used and received only one key. I needed another. I knew that you can program 8 additional spare keys but I didn't know that you must have two valid keys to create a spare. I took it to the Ford Dealer by driving my 2008 F150 and they told me that they needed the 2002 because they would have to reprogram the vehicle. Anyway, to answer your question, the cost was $75 for a reprogram, and the keys were $25.00. I purchased 2 additional keys so that I will always have two spares so that I can make may own.
Old 03-14-2008, 12:04 AM
don't pay to reprogram the keys...do a search...I'm almost positive it is a very similar process to reprogram the chipped keys as it is the key fobs. You can do it and use the money to pay for that "spare" key for next time!
Old 03-14-2008, 12:51 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
You can only program additional keys at home without a locksmith or dealer if you have 2 working PATS keys.
I had 2 working keys and bought a blank on Epay for $15, then had Hope Depot cut it. They didn't charge me because they could not guarantee that it would work. Well it worked fine and I programmed it.
So if you have 2 good PATS keys, get a third and save a bunch of money!!
Old 03-14-2008, 07:33 AM
Quote:
Sorry, but you are incorrect. No such process exists.
Steve
Keys Nathan00 2004 - 2008 F150 1 04-08-2015 02:21 PM
Reprogramming a 3 button key fob. Calixto 1997 - 2003 F150 3 11-09-2014 02:09 AM
replacement keys sudsmcduff 1999 - 2003 7.3L Power Stroke Diesel 6 09-21-2014 04:30 PM
PATS key work around? cobrarep Excursion - King of SUVs 12 08-03-2008 02:13 PM
replace ignition key yota 1961 - 1966 F-100 & Larger F-Series Trucks 1 03-03-2004 07:09 PM
Tags
2003, 99, buy, chiped, chipped, cost, f150, ford, key, keys, made, make, reprogram, securilock, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
