why no PARTIONALY HYDROGENATED VEGIE OIL? - Ford Truck Enthusiasts Forums
Old 03-12-2008, 08:27 PM
1994diesel's Avatar
1994diesel 1994diesel is offline
1994diesel is starting off with a positive reputation.
I know not to use it but why, will it damage the truck? even if you process it? and can it react with methoxide?
thanks
Old 03-13-2008, 09:13 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
If your BLENDING it will seperate more readily. It can be used to make bio just fine tho.
Old 03-14-2008, 12:24 PM
zhilton's Avatar
zhilton zhilton is offline
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
What about in a Vegistroke based WVO system? I know hydrogenated oil is really bad for our body....but for the truck after it's reached operating temperature?
85 6.9 vacuum pump shooting fuel out of it why mitchgordon96 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 07-20-2014 06:29 PM
Why are they called dent sides? Ripcity 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-17-2013 08:47 AM
Why don't diesels make vacuum? garrettsr5 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 05-15-2013 04:09 PM
Why was the Excursion discontinued? quader94 Excursion - King of SUVs 36 01-23-2010 10:21 AM
why is rear narrower haroldservice 1968-2013 Full Size Vans 11 04-05-2005 09:53 PM
Tags
partionaly
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
