dont mix green and yellow coolant? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-12-2008, 06:02 PM
john guard john guard is offline
john guard is starting off with a positive reputation.
ok, i must be an old guy because i remember when it was either water or green coolant!
anyway, i was looking thru my owners manual about the coolant for my 2008 Ranger and it tells me to use YELLOW coolant only.
i looked up Motorcraft coolant and it says dont mix yellow with green or with orange or with pink, red, blue, almond....you get the idea!
my question is what coolant other than Motorcraft can i use?
does prestone have a yellow coolant?
it should be a 50 50 mix according to my book.
Old 03-12-2008, 06:20 PM
Pablo-UA Pablo-UA is offline
Pablo-UA is gaining momentum as a positive member of FTE.
Yellow/orange coolant is usually used for european engines (2.9, 2.8 and 4.0). For made of cast iron 3.0 green was used.
But.... now all new trucks have yellow coolant (and with 3.0 too).
I mixed green and blue. All was good.
Old 03-12-2008, 08:59 PM
Bear River Bear River is offline
Former ******
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
Just use the Prestone coolant that says it is for everything. it is yellow/greenish (more yellow), and it has the required additive that allow it to work in just about any type of vehicle.
Old 03-12-2008, 09:12 PM
Dad's Truck Dad's Truck is offline
Dad's Truck is starting off with a positive reputation.
You can hit any of the auto parts stores and get Prestone all-in-one or whatever they call it. You can use it with any car, any year, any color. Yellow bottle, blue label if I recall correctly.
Old 03-13-2008, 01:47 AM
oldgoat49 oldgoat49 is offline
oldgoat49 is gaining momentum as a positive member of FTE.
That is what I did anyway. I was trying to keep the different types of anti freeze and then found the one for all and went with it.
Old 03-13-2008, 06:17 AM
PW01 PW01 is offline
PW01 is starting off with a positive reputation.
Use Zerex G0-5, it is the same chemical compound
Old 03-13-2008, 08:07 AM
ctboyle03's Avatar
ctboyle03 ctboyle03 is offline
ctboyle03 is starting off with a positive reputation.
I made the mistake of putting orange coolant in a car I had a few years ago. After a few months, the radiator had corroded through and had to be replaced...not sure if any other damage was done to the engine, but it ran fine. I definitely learned my lesson to make sure I'm using the right coolant for my vehicle.
Old 03-13-2008, 10:35 PM
GozInSnowz GozInSnowz is offline
GozInSnowz is starting off with a positive reputation.
A while back I read some auto expert's column and he said definitely do not use the all-in-one coolants.. I can't give you any reasons why not.. that's all I can remember, sorry..
*edit*
October 2005 — Ford Motor Company released recently a dealer/distributor FAQ communication to address the concerns over using “universal” coolants. Below is the verbatim from the communication.
Some companies market a “Universal” coolant claiming that their product can be used for all vehicle applications. What is Ford’s position on the use of “Universal” coolants in Ford vehicles?
Ford does not have performance data for the multitude of engine coolants available in the aftermarket and therefore cannot recommend the use of any coolant except those approved by Ford Motor Company.
Due to the complexity of cooling systems, no one coolant has been proven to work in all vehicles. “Universal” coolants generally do not contain silicates and nitrites, both of which are required for Ford vehicles equipped with Motorcraft Premium Gold Engine Coolant.
Thus, these “universal” coolants generally do not meet Ford’s coolant specification WSS-M97B51-A1.
Ford vehicles equipped with Motorcraft Premium Engine Coolant, meeting Ford specification ESE-M97B44-A, require silicates and, in the case of diesel engines, the use of Motorcraft Diesel Cooling System Additive, VC-8, which contains nitrites. Thus, these “universal” coolants may not be suitable for use in vehicles originally equipped with Motorcraft Premium Engine Coolant.
Based on blind laboratory ASTM testing performed in duplicate, two leading “universal” coolants currently in the marketplace did not meet the extended D2809 requirements of Ford’s Motorcraft Premium Gold Engine Coolant specification, WSS-M97B51-A1.
The “universal” coolants may not be compatible with Ford’s recommended supplemental coolant additive, Motorcraft Diesel Cooling System Additive, VC-8.
Use of non-approved “universal” coolants may lead to eventual engine damage or failure. Problems caused by use of non-approved “universal” coolant may not arise immediately, but may occur over longer periods of time due to additive compatibility issues.
Although the Ford New Vehicle Limited Warranty is not automatically voided upon the use of a non-approved coolant in Ford vehicles, if such use results in damage to the vehicle or its components, the cost of repairing the damage (and related damage) would not be covered by the Ford New Vehicle Limited Warranty.
What may be some of the consequences of using the wrong coolant?
Reduced corrosion protection of cooling system components, incompatibility with engine gasket materials, corrosive attack of aluminum components, cylinder wall cavitation and engine block damage in diesel engines and potential water pump issues.
What are the primary coolant types Ford recommends for use in its vehicles?
* Yellow-colored Motorcraft Premium Gold Engine Coolant, meeting Ford specification WSS-M97B51-A1
* Green-colored Motorcraft Premium Engine Coolant, meeting Ford specification ESE-M97B44-A
* Orange-colored Motorcraft Specialty Orange Engine Coolant, meeting Ford specification WSS-M97B44-D
What is the interchangeability of Motorcraft Premium Engine Coolant and Motorcraft Premium Gold Engine Coolant? Can Motorcraft Premium Engine Coolant be used to top off a vehicle equipped with Motorcraft Premium Gold Engine Coolant? Can Motorcraft Premium Gold Engine Coolant be used in vehicles equipped with Motorcraft Premium Engine Coolant?
Ford does not recommend mixing coolants. Green-colored Motorcraft Premium Engine Coolant should not be used in vehicles except those originally equipped with it.
However, based on the results of backward compatibility testing, certain vehicles originally equipped with Motorcraft Premium Engine Coolant can be serviced using the yellow-colored Motorcraft Premium Gold Engine Coolant as long as the following conditions are met:
1. If the green-colored engine coolant is thoroughly flushed out of the cooling system and then the system is filled with yellow-colored engine coolant, the service maintenance (change-out) intervals of the yellow-colored engine coolant can be followed.
2. If the green-colored engine coolant is not completely flushed out of the cooling system (e.g., yellow-colored engine coolant is used to top off the system), then the service maintenance (change-out) intervals of the green-colored engine coolant must be followed.
3. All pre-1999 vehicles, as well as all model years of Mercury Villager, must be serviced with the green-colored engine coolant.
Coolant Jay Raz Ranger & B-Series 1 11-21-2015 01:02 AM
Cooling System Capacity Big-Red-Lariat 2004 - 2008 F150 4 12-26-2010 01:33 PM
When to use VC-9 Benchwrench 6.0L Power Stroke Diesel 11 09-07-2010 02:33 PM
mixing coolant? dvfd12 1999 - 2003 7.3L Power Stroke Diesel 8 04-27-2009 09:49 PM
ByPass Coolant sample is Lime Green Vs. Yellow?? MoyockPowerstroke 6.0L Power Stroke Diesel 15 03-16-2009 10:13 AM
Tags
additive, coolant, engine, f150, ford, gold, green, mix, mixed, motorcraft, orange, premium, prestone, ranger, vc8, yellow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
