Another Electric Choke Question
I did a quick search, but no luck.
1984 E350, stock 460 with 4BBL carb
The choke and fast idle will not come down for a long time after cold start, even after blipping the throttle.
I reset the choke to the factory setting (I think) it calls for 3 rich.
It still takes a long time to come down from fast idle and choke, but it is a little better.
It has an electric choke, but the wire going to the choke housing is only reading 7.5 volts. I was assuming that this should be 12 V? Does anyone have a wiring diagram for the choke circuit so I can trace the wiring and find out if there is an issue causing the drop in voltage? Is 7.5 volts correct? I tried using a 12V tapped on the battery directly to the choke and it seems to respond (read - come down from fast idle) better.
Also, the choke also seems to have a pipe for manifold heat along with the electric choke housing, what gives. I've heard of electric choke, manual choke, and manifold heated choke, but is there an electric + manifold heat for the choke?
Thanks,
Dave
Thanks,
Dave
Originally Posted by 86rustbucket
Thanks, to check continuity, should I put one lead on the terminal and one on the coil itself? or on the backing plate behind the coil?
Thanks. Checked the continuity, nothing. I tried the same thing on my other 460 with a new carb and got a good reading so I know that my technique is right. I ordered a new choke thermostat today, $75 ouch. Hope this works.
bfricks
12-20-2016 02:33 PM
dan240
12-31-2015 11:40 AM
jim4
15
12-26-2008 03:03 PM
