351m short block - Ford Truck Enthusiasts Forums
351m short block
Old 04-09-2001, 10:58 AM
jcf250custom jcf250custom is offline
jcf250custom is starting off with a positive reputation.
351m short block
where can i find a short bock for my 351m? what would it come with, and how much can i expect to pay?
Old 04-09-2001, 11:23 AM
Bill_Beyer's Avatar
Bill_Beyer Bill_Beyer is offline
Bill_Beyer is starting off with a positive reputation.
351m short block
Short blocks consist of a block assembled with crank, rods, pistons, cam & timing components. I've never bought one because I rebuild my own but they should run in the $500-$750 range for a decent one. I understand that some remanufacturers don't do short blocks anymore. You might want to call around to the local chains to see what they can do for you.
Old 08-02-2001, 11:32 PM
PRIMER_78 PRIMER_78 is offline
PRIMER_78 is starting off with a positive reputation.
351m short block
Ill sel;l you my 351M im in NJ too far or close to you?
viktimized(No Email Addresses In Posts!)
Old 08-03-2001, 10:08 AM
beartracks's Avatar
beartracks beartracks is online now
beartracks is gaining momentum as a positive member of FTE.
351m short block
If you do buy a short block it's a good time to consider a 400. Everything else is the same but the cubic inches.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old 08-03-2001, 10:16 AM
Boss_358's Avatar
Boss_358 Boss_358 is offline
Boss_358 is starting off with a positive reputation.
351m short block
[font size="1" color="#FF0000"]LAST EDITED ON 03-Aug-01 AT 11:17 AM (EST)[/font][p]
Think about this one for a second. Everything is not the same if the cubic inches are different. The crank is all that is different wich makes the cubes different.
People who say it can't be done should not interrupt the person doing it.
Old 08-03-2001, 10:30 AM
Bill_Beyer's Avatar
351m short block
The crank and pistons are different.
Old 08-03-2001, 12:12 PM
Boss_358's Avatar
351m short block
Learn something new everyday!!
Old 08-03-2001, 01:23 PM
beartracks's Avatar
351m short block
Of course the crank and slugs are different but as far as the "rebuild" is concerned there is "no" difference. Every thing bolts up the same. Nothing extra to buy or screw around with.
1977 Ford F-100
280,000 miles
Old 08-03-2001, 01:28 PM
beartracks's Avatar
351m short block
351m to 460 with manual transmission 7379ford 1973 - 1979 F-100 & Larger F-Series Trucks 0 12-17-2016 03:49 PM
351C,351M/400 waterpump bolts POPAJON 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-17-2012 07:13 AM
what to build for '67 f100 street rod: 302 vs 351c/351w/400m relient3074 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 05-21-2008 07:24 PM
what is diff, between 351m + 351w pistons? rsalter66 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 05-28-2007 01:35 PM
351M or 351C warecreek 1961 - 1966 F-100 & Larger F-Series Trucks 7 01-25-2006 10:08 AM
Tags
1977, 1978, 351, 351m, 400, 58, block, blocks, f100, ford, motor, rebuild, rebuilt, sale, short, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
