Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 03-12-2008, 01:17 AM
Wildcat_1 Wildcat_1 is offline
Garage is empty, add now
Wildcat_1 is starting off with a positive reputation.
Front Grill and Rear Silver Hatch Handle Cover Oxidation
All
I have a Black 07 Eddie Bauer (with silver albeit plastic front grill and rear hatch handle cover, standard fare on EBs ). I noticed today what can only be described as looking like some form of oxidation on these. I washed the truck twice to try and remove it and even took a more abrasive approach on the front grill but cannot remove these discolored spots. It's not stuff stuck to it as it is smooth to the surface but more like something has started to discolor (want of a better description) these areas. I also noticed that the Expedition name on the rear hatch is starting to lose its black inner paint.
Anyone else experienced these things ?
I only brought the truck last June and personally think this should be covered but did not know if warranty would tackle these or not.
Thanks all
WC
  #2 (permalink)
Old 03-12-2008, 01:31 AM
As I am in Colorado I wonder if some of this has been caused by mag chloride during the snowier months but again with a truck that is barely 10 months old and still only has 6k miles on it this does not seem right. Could this be the same crap that is affecting the 20" rims with the chrome clad ?
  #3 (permalink)
Old 03-12-2008, 09:08 AM
07EXPYEL 07EXPYEL is offline
07EXPYEL is starting off with a positive reputation.
I had my front "chromed" grill replaced under warrenty after about 6 months & 10K miles. It was forming rust stains on the undersides of the slats. I had only been in rane a few times and never snow/salt.
  #4 (permalink)
Old 03-12-2008, 11:00 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
From low quality materials. Try waxing it to see if it helps.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #5 (permalink)
Old 03-12-2008, 11:57 AM
Rustin would be a great description of what was happening, didn't know it was possible with plastic
  #6 (permalink)
Old 03-12-2008, 12:18 PM
berry1234's Avatar
Can you post some pics?
__________________
  #7 (permalink)
Old 03-12-2008, 03:07 PM
IQ9 IQ9 is offline
IQ9 is starting off with a positive reputation.
Try using some KLASSE on it. Look online for it. The stuff is used in Germany for waxing airplanes. It works really well on oddball stuff like this.
__________________
White Sand 08 Expy EL Limited 4x4 with everything but the power running boards & trip tunes.
  #8 (permalink)
Old 03-12-2008, 05:08 PM
rich93cw rich93cw is offline
rich93cw is starting off with a positive reputation.
Magnesium Chloride is really aggressive material, corroding commercial trucks significantly faster than other ice melting materials. The industry has a big problem with it and the states know it, but still use it because it is best under really cold temperatures.
What you may be seeing is the "chrome" corroding. It is really not chrome, but aluminum that is placed on the plastic grille and other plastic parts. Typically, there is a coating on the aluminum. When aluminum corrodes to aluminum oxide, it turn clear, because aluminum oxide is clear. The same thing happens to the insides of sealed beam headlamps when they get a stone hit. After a short while, the shiny aluminization apparentily disapears and you can see right through the headlamp. Again, that is because aluminum oxide is clear. It is still there on the headlamp reflector, its just not shiny.
  #9 (permalink)
Old 03-12-2008, 05:14 PM
My grill had a difinite rust colored spots. If there was also aluminum oxide, I didn't notice it. From my experience, aluminum oxide is like a white powder, not clear.
Tags
chloride, difinition, ford, front, grill, grills, handles, hatch, mag, oxidation, oxydisded, remove
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
