Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 03-11-2008, 08:16 PM
Tom D Tom D is offline
Garage is empty, add now
Tom D is starting off with a positive reputation.
Cool Bad Batch
OK all you chemists. What did I do wrong? Please look at last post by me under "First Batch" Appreciate all the help. Tom D
__________________
93 F-250 7.3 Banks turbo, 3.5" exhaust 4" ram air K&N filter E40D 4.10. Pyro, boost, & tranny temp gauges. Tru Cool 28,000 GVW trans cooler. 100% BIO
  #2 (permalink)
Old 03-11-2008, 08:32 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
First a couple of questions Tom. If your titration numbers are correct, did you add 9.8 grams for EACH liter? That would be 196 grams KOH mixed with 1 gallon of Methanol.
How long did you mix for?
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 03-11-2008, 08:39 PM
I added 9.8 grams to the 20 liters (approx 5 gallons) which was 196 grams. Correct?
I mixed for 30 minutes.
__________________
  #4 (permalink)
Old 03-11-2008, 08:53 PM
1935 Ford pickup
Sounds like you might have some suspended water. Did you do a pan test on the oil first? What condition was the oil in, color, smell etc.
__________________
  #5 (permalink)
Old 03-11-2008, 08:54 PM
Hey Don. Thanks for the reply. I think I know what I did wrong. STUPID OF ME. I think I added 19.6 grams instead of 196. Now what can I do to recover? Can I just reheat to 145 deg and add approx 176-177 grams to make up the difference? Do I have to add methanol or can I use just enough to liquify the KOH like maybe a quart?
__________________
  #6 (permalink)
Old 03-11-2008, 08:57 PM
The oil was in very good condition. It smelled very good when I heated to 150 deg. (made me hungry) I did not pan test it but I thought 150 deg would solve the moisture problem.
__________________
  #7 (permalink)
Old 03-11-2008, 09:10 PM
1935 Ford pickup
From what your discribing I'll bet you were off with the KOH. I would just add the remaining KOH after reheating and mix for 1 hour. This should work. Trying to add 150+ grams to a small amount of Methanol will create a TON of heat when it reacts.
__________________
  #8 (permalink)
Old 03-11-2008, 09:15 PM
I need to leave town for a week. Can I leave BD in separator without removing the KOH or Methanol or will it burn a hole in the steel drum?
__________________
  #9 (permalink)
Old 03-11-2008, 09:23 PM
1935 Ford pickup
Yes you can leave it for a week, but unless the tank is air tight you may lose some of the methanol due to evaporation.
__________________
  #10 (permalink)
Old 03-11-2008, 09:26 PM
Quote:
The tank is air tight. Thanks for the assistance. I will re-cook it tomorrow and post the results before I leave town. Tom
__________________
  #11 (permalink)
Old 03-12-2008, 09:59 AM
sstipiotis sstipiotis is offline
sstipiotis is starting off with a positive reputation.
Dont you have to be careful heating the mix hoter than the boiling point of the methanol (like 140 degress+)?
  #12 (permalink)
Old 03-21-2008, 04:37 PM
Angry
I'm back from trip and checked small amount I had poured into mason jar before I left. It separated for 8 days. There is a definite separation of BD and glycerin but it took quite a while to separate. The BD looks black but when I hold it to the light, it is VERY dark maroon color. I can see light through it. It doesn't seem like I have performed a good process. What do you think?
__________________
  #13 (permalink)
Old 03-21-2008, 10:40 PM
Knotwild Knotwild is offline
Knotwild is starting off with a positive reputation.
I would have suggested re-titrating it first, then running the batch with the new titration results.
__________________
97, Regular cab 4x4, 5sp, 3" downpipe, 4" MBRP exhaust, 6637 intake mod, Dieselsite 203 thermostat, Airdog II electric fuel system with fuel bowl delete.
  #14 (permalink)
Old 03-24-2008, 09:03 PM
TxFordGuy TxFordGuy is offline
TxFordGuy is starting off with a positive reputation.
How do you know when you have a bad batch? Has anyone used any of these dry wash systems out there? Also where do yall store your methanol? Outside? Will texas heat, heat the container enough to make it explode? what if i have a gas water heater in my garage?
  #15 (permalink)
Old 03-24-2008, 09:07 PM
Quote:
Good suggestion. I ran a titration and it says the batch is OK. I ran it 3 times to double check. I just thought it was too dark in mason jar but it looks pretty good in the syringe. I don't guess I can do a 3/27 test until I remove the methanol and dry it, right?
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
