7 pin Trailer wiring help - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 09-02-2008, 04:46 AM
tripledeuce's Avatar
tripledeuce tripledeuce is offline
tripledeuce is starting off with a positive reputation.
Well...apparently I'm not alone on this issue. I've searched numerous other forums, where Ford owners are experiencing this very same issue. This is the only one that provides any amount of insight to the problem.
I've got a 2000 F150, with the 7 - 4 barrel plug connection. I just bought a small ATV trailer. I've got signals and brake lights, but no marker lights. I see that several of you folks have recommended to check fuse #38 near the kick panel. Apparently that must only apply to the F250 and up models? My panel only has 31 fuse locations, and 5 relays....which are all good. The power dist box under the hood has several fuse/relay locations that appear to be relevant, and they are all good as well.
I've checked the plug outlet, and checked the wiring back as far as I could with a test light, and got nothing on the brown wire (for marker lts). At that point I gave up.
Looks like I may have to do some re-wiring.
  #32
Old 09-02-2008, 06:34 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Please note that this discussion was related to the 04 and newer Super-duty trucks. Your older vehicle is completely different after the model change-over for 2004.
I'll post a link to your relevant schematic shortly, I need to move to a different computer.
Edit: Here you go: http://www.mediafire.com/?3n2yzydm1c9 See sheet 95-3
Verify the running lamp relay energizes when the headlights are turned ON ( light toush will allow you to feel it click). Check fuse F5 in the under-hood box, it supplies lamp power for the trailer marker/running and backup lamps.
Steve
  #33
hammer65 hammer65 is offline
hammer65 is gaining momentum as a positive member of FTE.hammer65 is gaining momentum as a positive member of FTE.
There is another thread on this subject. It seems that on the 250 anyway, that there is a relay built into the fuse panel, and is not repairable. A new panel is required. Someone posted, how to wire in a new relay on the outside and wire around the failed one. I did it and it worked for me. You will need to start at the fuse that controls your hitch running lights and go from there. A search on the problem should bring it up. I too am new to the forum,and don't know how to find it, but there is a lot of nice people on here that are willing to help.
  #34
Old 11-26-2008, 11:39 AM
hornfan hornfan is offline
hornfan is starting off with a positive reputation.
I have a 2000 with the same problem. does the non-serviceable relay apply to the 2000 as well?
  #35
Old 11-26-2008, 02:14 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
2000 F250. This year does have a serviceable relay for the trailer running light circuit. It's in a "instrument panel relay block". All they say is it's behind the instrument panel as far as location.
In 2000 you have a fuse #4, 20 amp in the underhood fuse box. This fuse feeds the reverse relay and the trailer running light relay. After it passes through these relays, it heads on back to the plug.
  #36
Old 12-06-2008, 02:15 PM
Luv2RV Luv2RV is offline
Luv2RV is starting off with a positive reputation.
7 pin trailer wiring help
PADIRT I am having the same problem with my '99 F350 supercab. The turn signals & brake lights work but no running lights or tail lights. Not a problem if I only drive during the daytime But I still have to find the problem.
  #37
Old 03-30-2010, 10:33 PM
TexAcoon TexAcoon is offline
TexAcoon is starting off with a positive reputation.
[quote=Maxium4x4;5878313]THE TRAILER LAMPS ARE INOPERATIVE — TRAILER PARKING LAMPS
Maxium4x4 would you happen to have the drawing on the 7 pin plug and what connector is for what for a 2009 F250? ..
Apparently I'm having problem with my center pin .. My understanding it's the 12v supply..
What I am trying to do is run that to a battery located in the trailer to keep it charged. When I connect the wire to the battery in the trailer my trucks backup lights come on.
Seems that there is a wire mismatch going from trailer to truck's backup lights....
  #38
Old 03-30-2010, 10:39 PM
Quote:
I had that same problem ...
My issue was a bad ground wire to the clearance lights were not making a good connection ..
You may want to make up a small jumper wire and use it as a temporary ground just to see if one of your clearance lights light up with your headlights on and someone outside the trailer .....
  #39
Old 05-30-2013, 08:31 AM
Raeanne Knull Raeanne Knull is offline
Raeanne Knull is starting off with a positive reputation.
Parking lamps
03 Excursion with trailer package- parking lamps stayed on all the time. Stayed on when switch was taken out and when security module was taken out. Someone unhooked the wire from the tail lights to the trailer plug- the lights wouldn't turn off. Constantly on. Customer didn't do it, so we have no clue. Pull fuse 38 and the lights would shut off but than the trailer lights wouldn't work. Thought it was the parking relay, which of course is NON serviceable so you would have to get a new fuse box (complete) or run a new relay. We ran the new relay and it still had the problem, of course until we saw the brown wire in the back of the truck running from the tail lights to the trailer plug....
Very frustrating, but it works now like it should!!!
Just thought I would add to this old thread because it did help us look into this problem. And I have no clue who or why the wire was ran...so you never know if someone else does the same thing now knowing what it will cause!!!
  #40
Old 05-30-2013, 09:52 AM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is online now
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
Nice to know and you finally got your first post in Raeanne Congrats
  #41
Old 08-06-2013, 08:06 PM
kdwellsr kdwellsr is offline
kdwellsr is starting off with a positive reputation.
Is the Blue wire in the trailer plug suppose to have power all the time when the key is on?
  #42
Old 08-06-2013, 08:18 PM
Franklin2's Avatar
Quote:
What truck? Is this a 6 pin or a 7 pin plug? If it's the brake wire, no. Are you using a 7 pin to 6 pin adapter?
  #43
Old 08-06-2013, 08:23 PM
92 F250 Blade 7 pin. Blue brake wire. Brake controller light is working properly but I changed the round pins to blade pins but the blue brake wire was before and is now ,,,shows 12volts when I turn on key.
Trailer brake wiring and brake controller 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 1 06-25-2014 07:43 AM
Trailer light trouble mitsudave 1997 - 2003 F150 13 10-24-2012 06:27 PM
Horse trailer interior lights question brentnewjr 1999 - 2003 7.3L Power Stroke Diesel 7 09-11-2010 11:13 PM
Blowing trailer lights fuse. Billyclub Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 10 05-18-2010 12:11 AM
'03 F150 Trailer brake/turn light problem odiemallard Electrical Systems/Wiring 2 05-30-2008 08:12 AM
Tags
2004, 7pin, adapter, charge, diagram, electrical, f150, f250, ford, pin, pole, trailer, truck, voltage, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
