weird noise please help
ok i bout a 2004 ford f150 extended cab 2 weeks ago and last weekend i was on my way up north and i hear this weird humming noise coming from somewhere up front. well it only last for like a sec or two and dies out. well it did it three time that day. it does it everyonce in a while in the morning only. but when i drove last weekend it did it 2.5 hours in to a trip up north. well yesterday on my way to work it did it a lot. i cant really explain the noise but its just a humming type noise. it would do it for a sec or two and stop and come back a minute later and go off and so on for like 10-15 minutes prolly did it a total of 20 times. should i be worried? should i take it to the dealer? the dealer i got it from is a half hour away and dont wana take it there for them to tell me its nothing or they dont know. it only really happends in the morning.
I have a 04 explorer that's had a high pitched whine on cold days ever since I bought it. It comes and goes based on specific RPM's. I've come to the conclusion that it's the crankshaft pulley singing out with a minor imbalance or roughness in the engine brought on by the cold. When you said you went up north, and it did it in the morning only, I started to think your truck has the same issue. Ford thought I was nuts, but I brought them a video of it doing it and they still said they couldn't find any problems.
well im no mechanic but if it was the altenator wouldnt my battery be toast by now? i cant really see it being the hubs but once again im not a mechanic cause i mean it only does it in the morning except last weekend when i went up north. its like a high pitch humming noise. can this be a bad thing? cause i found out after i bought my truck from this ford dealer a guy from my work bought a f350 and they put a thicker oil in it to reduce the engine knock and when he changed it he put the regular oil in and his motor went not to long after that. should i get this checked out. could my motor be going? i have no clue where to begin.
Ok I did a quik search...here it is.
https://www.ford-trucks.com/forums/6...whinning+noise
