I couldn't get the movie to download, what kind of process was it?
__________________
1997 F250 Crew Cab 4x4
1988 F350 7.3 Crew Cab 4x4 Dually C6 w/ GearVendors Overdrive currently in a deep sleep until motor overhaul is finished. 1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual. (3) 1976 F250 Reg Cab 4x4 All 390, two C6 and one 4 spd.
Wow.......The "farm level" sounds extremely interesting. I've got 5 acres here, so I should be able to produce what....4.5 million gallons per year. Tho I would be perfectly content with about 100 gallons per month.
Any idea as to what the catalyst is?
__________________
Scott - FTE moderator
01 F-250 Lariat, 7.3, ZF-6, NV271, -38R, SII splits, DI tunes, Custom fuel, 5" stacks, IDM140....and more little mods than I can remember.
My sister in law works there as a financial aid councilor maybe Ill shoot her an email and see if they would share. They have filed a patent so it will be public shortly I am sure there is a way to adapt this to small scale private production.
very cool and exciting; this could be worth watching and investing in; I especially like the proposed use of algae oils; we can grow this stuff just about anywhere
Sounds very close to Fabmans pulse mixer that he came up with a good while back. I dont get yet how they are getting away from the Koh or NaOh. That would be great then. Invest invest invest buy stock hurry up.
The video says they are using a Sulfated Metal Oxide Catalyst instead of KOH or NaOH for the catalyst. If I understand their process correctly it sounds like the Sulfated Metal Oxide Catalyst is a form of solid acid catalyst. If this is correct then that also explains why they are not producing any soap since they are not using any bases such as KOH or NaOH. I wonder how much energy it takes to reach the operating temps and pressures for the process to work?
Jim
