what is magnasol - Ford Truck Enthusiasts Forums
what is magnasol
Old 03-11-2008, 12:13 AM
bobrl13 bobrl13 is offline
bobrl13 is starting off with a positive reputation.
Question what is magnasol
has anyone used magnosol? On the Magnosol web site they talk about dry washing your bio. How do you do that? It sounds like a good idea.
Old 03-11-2008, 09:20 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Magnesol is a chemical sponge. It will soak up unreacted chemicals, water, and other impurities in your fuel. Failure to remove these contaminants results in poor quality fuel that can damage your engine. The original method of decontaminating newly made BD was water washing but there are problems with that method and it also requires a drying step.
Chemically it is synthetic Magnesium Silicate. It is FDA approved for removing impurities from shortening, its' original purpose.
To use add the appropriate amount to your processed fuel and mechanically stir, do not use pump mixing. Then filter and use the fuel.
Fabmandelux, one of our forum members, produces a lot of BD and uses Magnesol. He has had his product tested and it meets ASTM standards.
do these things really flip? Scramblermaster Bronco II 37 10-01-2011 07:02 PM
Do you do your own work on your Aerostar? Racerguy Aerostar 13 08-09-2004 09:48 PM
Do you think that we are on the road to socialism? Mike W General NON-Automotive Conversation 24 09-12-2003 11:01 PM
how do I make a signature motobub User Gallery & Picture Display 4 01-09-2003 02:16 PM
Chips, do they help? Pastmaster Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 4 04-21-2000 09:13 PM
Tags
aprove, fda, filter, magnasol, magnesium, magnesol, silicate, similar, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
