Can Bio really be this easy?
On another bulletin board, people were whining about diesel prices, and somebody posted this easy "recipe" for biodiesel:
The person who posted it claims to know someone who has been running a truck on it for a year with no issues. But I'm a little skeptical. It seems like if it was really this easy, all the folks who are using much more complicated processes would have caught on. I don't know much about creating BD, but from what I've read here, glycerine removal seems to be important, and this doesn't seem to allow for that, unless they're catching it in those water filters, which doesn't seem likely.
Any thoughts? Is this a good way to save money, or a good way to ruin an expensive engine?
Quick and easy quasi-biodiesel recipe:
15 gallons used veggie oil
5 gallons Kerosene
1 gallon Gasoline
1 pint Heet
Mix. Filter through two household water filters (5 micron) until it looks and feels like diesel fuel.
If you get your oil free, this should be under $1/gallon. No modifications to the truck are needed.
5 gallons Kerosene
1 gallon Gasoline
1 pint Heet
Pure Snake oil!
Really, you where right the first time. A sure fire way to ruin your engine.
The ONLY way to make Biodiesel is transesterification, anything else is just blending.
I have been running a mix similar to this for 2 years, as long as you stay away from hydrogenated oils and/or lard, and filter properly, you should run find through a NON ELECTRONIC Engine. I don't know how it would run in an electronic engine, I haven't tried it, I'm kind of scared to. A 93 back Dodge works best, it will even start on the coldest mornings on the mix. I have recently added a heated fuel filter, not a big time heated tank system, but a simple Heated fuel filter I bought from Racor for $150 . It works great, my truck seems to have more power since that addition.
Mean_Green
54
04-23-2010 02:51 PM
nlemerise
10-11-2008 07:39 PM
derherr65
Bio-diesel, Propane & Alternative Diesel Engine Fuels
66
04-23-2007 08:23 AM
