Question about intercooling & engine mechanics
Alright guys, so I was on the john (where I do al my best thinking) and was thinking about intercooling (why i was, i do not know...)...Now correct me if I'm wrong, but the way the PSD, and most diesels work is air enters the cylinder, under positive pressure from the turbo, and is compressed, thus heated. Once the piston reaches TDC (or a micro second before that) fuel is injected under extremely high pressure, enough to overcome the compresses hot air (why we need HPOP) and because the air is so hot, the atomized fuel ignites. Correct so far?
NOW an intercooler taked the compressed air, and cools it, also making it denser before it enters the combustion chaimber. The air is then compressed and ignited. So...
Is because the cooler air is denser (thus you could fit more cooler air in the same area as a hotter air) the reason that a intercooler is benificial? I'm assuming that it gets up to the same temp when compressed so that when the diesel is injected it can be ignited... and I know that an intercooler results in lower EGT's (I think) just trying to see where the actual performance is gained.
My theory is: more cooler air can fit in the cylinder than hotter air, thus there is more air available for air/fuel mixture thus more power... sound right?
-Robb
-Robb
on
Robb you are right on. IC cools the intake air that is heated when compresser (and absorbs heat) from the turbo. The more dense air enters the cylinder and is compressed which heats it then fuel is injected and lite by the hot air.
IC do lower EGT's. I saw 150-200 drop in mine. I can't really explain it but I think it has more to do with O2 volume than it does with temperature.
