1998 F-150 fuse location
Old 03-10-2008, 09:01 PM
johnnyford1's Avatar
johnnyford1
johnnyford1 is offline
Angry 1998 F-150 fuse location
Have 1998 F-150 need to know what fuse and what location to replace fuses on the fuse panel. Heater will blow but no heat . Any help would be great
Old 03-11-2008, 12:16 AM
Club Wagon's Avatar
Club Wagon
Club Wagon is offline
Just a hunch, but it doesn't sound like any fuse to me. Suggest you do a search here on FTE. These pickups are well known for a variety of heater problems. Yours sounds like either a PITA vacuum operated blend door failure or possibly the nefarious **** slipping on shaft issue.
Old 03-11-2008, 05:47 AM
johnnyford1
thank you for your reply
Old 03-11-2008, 06:32 AM
Joe Finn's Avatar
Joe Finn
Joe Finn is offline
Try switching the fan and temp ***** first and see if that fixes it.
Old 03-11-2008, 10:35 AM
typhus's Avatar
typhus
typhus is offline
Mine did the same thing.... the ole **** slipping on the shaft thing. Even though it felt tightly secured, it wasnt grabbing the shaft, and therefor no heat or adjustability.
Start simple, and then address the other complex issues.
**** was 22 dollars from the dealer.
topdog49646
1997 - 2003 F150
09-06-2016 04:54 PM
KobeAlbo
1997 - 2003 F150
05-25-2014 05:13 PM
sinco039
06-11-2013 09:44 AM
Carp824
1997 - 2003 F150
09-28-2004 08:48 AM
khoupt
1997 - 2003 F150
09-13-2004 11:45 AM
Quick Reply: 1998 F-150 fuse location
