1998 F-150 fuse location - Ford Truck Enthusiasts Forums
Old 03-10-2008, 10:01 PM
johnnyford1 johnnyford1 is offline
johnnyford1 is starting off with a positive reputation.
Angry 1998 F-150 fuse location
Have 1998 F-150 need to know what fuse and what location to replace fuses on the fuse panel. Heater will blow but no heat . Any help would be great
Old 03-11-2008, 01:16 AM
Club Wagon Club Wagon is offline
Club Wagon is gaining momentum as a positive member of FTE.
Just a hunch, but it doesn't sound like any fuse to me. Suggest you do a search here on FTE. These pickups are well known for a variety of heater problems. Yours sounds like either a PITA vacuum operated blend door failure or possibly the nefarious **** slipping on shaft issue.
Old 03-11-2008, 06:47 AM
thank you for your reply
Old 03-11-2008, 07:32 AM
Joe Finn's Avatar
Joe Finn Joe Finn is offline
Joe Finn is gaining momentum as a positive member of FTE.
Try switching the fan and temp ***** first and see if that fixes it.
Old 03-11-2008, 11:35 AM
typhus's Avatar
typhus typhus is offline
typhus is starting off with a positive reputation.
Mine did the same thing.... the ole **** slipping on the shaft thing. Even though it felt tightly secured, it wasnt grabbing the shaft, and therefor no heat or adjustability.
Start simple, and then address the other complex issues.
**** was 22 dollars from the dealer.
Help with 2002 F150 fuse panel {location of fuses} topdog49646 1997 - 2003 F150 2 09-06-2016 05:54 PM
1998 F-150 4x4 Air conditioning Fuse KobeAlbo 1997 - 2003 F150 7 05-25-2014 06:13 PM
Help: 1998 150 Conversion Van - TV/Trim Lights not working sinco039 1968-2013 Full Size Vans 9 06-11-2013 10:44 AM
Power Window Problem 1998 F-150 Carp824 1997 - 2003 F150 5 09-28-2004 09:48 AM
fuse panel in 1998 f150 4x4 reg. cab khoupt 1997 - 2003 F150 3 09-13-2004 12:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
