351m EGR - Ford Truck Enthusiasts Forums
351m EGR
Old 03-30-2001, 01:19 PM
79fordslug 79fordslug is offline
79fordslug is starting off with a positive reputation.
351m EGR
I am going to install a 4bbl carb and performance intake on my truck. the current set up has EGR with the carbon canister and the lines going all over. I want to pull all the EGR out including the carbon canister to simplify the engine and to gain more vacuum pressure. Should I pull it off and can I just block holes in the intake, carb, and gas tank? or should I leave it on and match it to my performance intake?
Old 03-30-2001, 02:54 PM
firstonraceday's Avatar
firstonraceday firstonraceday is offline
firstonraceday is gaining momentum as a positive member of FTE.
351m EGR
I think you will need to stay with the EGR. I have seen spacer plates in the Summit catalog. Taking it out, I believe, will increase pinging and negatively affect performance. I have a 351M in a 1977 F-250 and the spacer will get partially blocked with carbon periodically. When this happens, it will ping no matter the octane grade of gasoline. Someone with more familiarity with this engine design may have a different but, if everything is currently intact as far as the system, I would leave it in.
Old 03-30-2001, 06:36 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
351m EGR
If you go with an afermarket non-emission carb, you can do away with the egr. firstonraceday is correct about pinging IF you keep the original emission carb. Do not plug the line from the gas tank. This is a vent line and needs to be open. You may get a gas smell from this, but there's nothing else to do since the gas cap is sealed and the fuel tank needs to get air from somewhere to replace the fuel when the engine uses it. One recommendation I have is to keep the original air cleaner and tube going to the exhaust manifold. This will help driveability when it is cold.
Old 04-01-2001, 12:26 AM
bubbaf250's Avatar
bubbaf250 bubbaf250 is offline
bubbaf250 is starting off with a positive reputation.
351m EGR
>on my truck. the
79fordslug,
The carbon canister is not related to the EGR; it is part of the evaporative (EVAP) emissions control system. It's purpose is to capture fuel vapors from the fuel tank(s) and the carb bowl in the carbon canister when the engine is not running, then burn them off each time the engine reaches operating temperature. The EVAP system has no affect on performance.
> I want to pull
Unless you have leaky vacuum switches or hoses, the EGR and EVAP systems should have no affect on manifold vacuum.
>Should
>I pull it off and
>gas tank?
The EGR system on M-block engines (351M/400) consists of exhaust passages in the intake manifold, an adapter plate under the carb, and vacuum operated the EGR valve itself. The carb has no EGR ports or fittings.
You can disable the EGR by simply plugging off the vacuum hose that operates the EGR valve. If you disable the EGR, you must tune the carburetor to operate correctly without EGR (i.e., enrich the mixture). EGR allows excessively lean mixtures to be run without pinging.
>or should I
For future emissions compatibility (even if you decide to disable the EGR), I suggest an EGR-type manifold, like the ones provided by Edelbrock and Weiand. If you choose the Edelbrock manifold, their EGR manifold's carb mounting pad is much better than the one on the non-EGR manifold.
BubbaF250
1980 F250 4x4 Custom, 351M/NP435/NP208/D44HD-TTB/D60-FF/3.55s 6750 GVW, Rust & White.
Old 09-11-2001, 02:44 AM
GT40man GT40man is offline
GT40man is starting off with a positive reputation.
351m EGR
bubbaf250 is right, get the edelbrock egr manifold and id op for the 4 bbl egr spacer.
Old 09-21-2001, 02:02 AM
Bull Bull is offline
Bull is starting off with a positive reputation.
351m EGR
I have my EGR disabled (EGR valve vacume hose disconnected with EGR block plate in) on my 400 and don't have any pinging problems with 85 oct gas. I bought Edelbrock non-EGR intake manifold as it'll get rid of the whole EGR system for cleaner look. I'd test to see if your engine will ping with EGR disabled, and if it doesn't, go for it!
Old 09-21-2001, 01:35 PM
jwtaylor jwtaylor is offline
jwtaylor is starting off with a positive reputation.
351m EGR
Old 09-02-2010, 11:20 AM
hummer1bronco hummer1bronco is offline
hummer1bronco is starting off with a positive reputation.
Smile
Hello am new at this
am helping my son fix his 1980 bronco and need a dirgam for 1980 ford bronco 351m emision for the vacum lines
Ford 302 - 2bbl to 4bbl conversion questions Rusty_S Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 06-22-2016 08:52 AM
78 f150, just installed elec fuel pump, runs great! but has gas smell in engine compartment? F350dog 1973 - 1979 F-100 & Larger F-Series Trucks 1 09-23-2015 07:46 AM
Replace or Clean an EGR valve? aballiett 6.0L Power Stroke Diesel 12 08-11-2015 06:05 PM
89 5.8 help identify a few mystery vacum lines zspeed130 1987 - 1996 F150 & Larger F-Series Trucks 1 09-28-2014 11:24 AM
Please help me get my EGR working Fordman18 1973 - 1979 F-100 & Larger F-Series Trucks 17 02-18-2012 05:43 AM
Tags
1977, 1980, 351m, 54, 66, adapter, block, canisters, carb, egr, ford, function, intake, motor, system, tune, vapor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
