Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-10-2008, 01:59 PM
swcash is starting off with a positive reputation.
5.4 blew plug, now won't stay running
My e350 1997 5,4 blew a plug out of cylinder #3. I had the top end apart except for the heads and repaired the threads and replaced the cop with a coil from a 2003 4.6.
I got it all back together and now it starts, but won'ty stay running. It will run for about 2 seconds and then sounds like it's running out of gas. I think I hear the fuel pump shut off.
Can anyone give me an idea where to start looking for the gremlin?
Check engine light has been on since plug blew out. What does it take to clear the original fault?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-10-2008, 02:31 PM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
Simply disconnecting the battery for 15 minutes will do it.
I'd suggest measuring the fuel pressure with a gauge to see if you're loosing pressure.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 03-10-2008, 03:12 PM
wtroger is starting off with a positive reputation.
Make sure all the sensors are hooked back up. The fuel pump will run for 2-3 secs when you turn the key on pressurizing the system. Then before the pump will run again the pcm needs to know if the engine is turning over. Sounds like it isn't getting that signal I would assume it would be the crank shaft position sensor or what ever delivers the tach pulses
  #4 (permalink)
Old 03-10-2008, 06:23 PM
thanks for the comeback fellows. The fuel pressure is steady. I got a code reader and found the wires off of one cop. Still won't stay running.
Found connection on air intake after air filter was not on correctly. The 4 inch hose clamp wasn't on properly. Fixed it and she purrs like a kitten.
Thanks everyone for the help. Foe a while I felt likle I was down and out in Bevrely Hills. Actually Anaheim.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
