Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 03-10-2008, 02:33 PM
WWolf WWolf is offline
WWolf is starting off with a positive reputation.
2.5l engine block identification
Hello,
Is it possible to tell the difference between a 2.3l and 2.5l block externally?
Thanks
  #2 (permalink)
Old 03-11-2008, 08:13 AM
tomw tomw is offline
tomw is gaining momentum as a positive member of FTE.
The difference between versions of the 2.3 are mostly related to fuel pump, oil pump and ignition/distributor. The 2.3 and 2.5 share the same block, the different displacement being done by lengthening the stroke. The 2.0 has a smaller bore. There IS a difference somewhere in time with the crankshaft journals.
There is at least one post here that details ALL the differences...
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #3 (permalink)
Old 03-11-2008, 10:23 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
Hi, Welcome to the site!
Here's a link to the thread I believe Tom was referring to:
http://www.ford-trucks.com/forums/40...-vs-2-5-a.html
Starts off a little slow but the info you need is in there, just read down a bit.
See ya around!
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #4 (permalink)
Old 03-12-2008, 03:34 AM
Thanks for the info!!!
Tags
block , engine , ford , identification
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
