Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 03-10-2008, 01:50 AM
1994diesel's Avatar
1994diesel 1994diesel is offline
Garage is empty, add now
1994diesel is starting off with a positive reputation.
truck isnt running right on veggie oil
hi, im new at all this bio diesel stuff, but i have been putting little bits of vegtable oil in my truck, the oil i get is reaalllyyyy used its almost not even clear, dark color but about a dark carmel color in the sun, i filter it though a metel mesh filter, but i idles terribly and smokes alot, is this just bad quality oil or do i need to refine it more, oh and i ran about 2.5 gal. of veggie oil and 2.5 gal of diesel, so 50/50, and it is partially hydrogenated. what do i do? am i hurting my truck?
__________________
Justin
94 F-250 Turbo Diesel, 7.3L IDI, E4od, 4x4, long bed, ext cab, pyrometer, ATS boost gauge, IP turned up 2 flats, Straight pipe
93 F-250, 7.3L IDI, E4OD, 4X4, long bed, ext cab, straight pipe... almost.
  #2 (permalink)
Old 03-10-2008, 06:41 AM
UFMcG UFMcG is offline
UFMcG is starting off with a positive reputation.
I'm not fully edjumakated about biodiesel, but from what I've read, yes, you are hurting your truck. Using straight vegggie oil especially used is putting soaps and water and probably little bits of french fries through your engine. To run straight veggie there are mods you have to do to your engine to enable it to handle all the extra goodies. Even then your engine's not going to last as long as it should. Do a Google search on bio diesel. There is a plethora of sites that will tell you what's involved.
  #3 (permalink)
Old 03-10-2008, 07:50 AM
firemediceric's Avatar
firemediceric firemediceric is offline
firemediceric is starting off with a positive reputation.
I can't imagine that the mesh filter is anywhere near fine enough for adequete filtering. You also don't mention doing anything to make sure the WVO is water free.
I believe you need to rethink your process and maybe plan on putting in a little more time and effort if you want to continue down this road.
__________________
1999 F-350 with Tymar type air filter, Dahl 100 fuel filter, HP oil X-over, bypass oil filter, coolant filter.
  #4 (permalink)
Old 03-10-2008, 10:22 PM
1994diesel's Avatar
well hold on, im not running it on svo, im running a diluted mix of veggie and diesel #2, and wouldnt i be able to tell if their is water, wouldnt it evaporate if i heat it up? i let the veggie oil sit for a couple of weeks also before i filter it, im not completely ignorant!!! lol i actually used to use coffee filters but that took quite a while and they got clogged quickly, as for the mesh filter i cant see any contaminants, but i want to know why it was smoking so much?
__________________
Justin
  #5 (permalink)
Old 03-10-2008, 11:42 PM
bobrl13 bobrl13 is offline
bobrl13 is starting off with a positive reputation.
Stop putting that stuff in your truck before it stops running completly and look at this web site. http://www.biodieselcommunity.org/mainpage/ It willl tell you everything you need to know. By the way vegitable oil does not mix with diesel unless you process it properly.
  #6 (permalink)
Old 03-11-2008, 12:16 AM
Wookie35 Wookie35 is offline
Wookie35 is starting off with a positive reputation.
You need to use at least a 5 micron filter to get all the crud out of the oil. Some folks use a centrifuge to remove some of the junk and then heat it to remove the water. Water will not just evaporate as the oil is pushed into the cylinder and water does not compress very well at all. It is a good way to bend a rod or worse! There are lots of resources on the web to get some better guidance from. Do yourself a favor and do some research before you experiment on your ride. The research is free, how much does a reman 7.3 cost?
  #7 (permalink)
Old 03-11-2008, 10:25 AM
Quote:
A hot pan test would be a good indicator of water in the oil, including the water that you can't see and that won't seperate out just by sitting.
I filter down to 1-2 micron nominal. See my signature. But what do I know?
You may want to check out http://biodiesel.infopop.cc/eve/foru...m/f/9751014871
__________________
  #8 (permalink)
Old 03-11-2008, 11:04 AM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
NO PARTIALLY HYDROGENATED!!!!!!!!! You have to stay away from partially hydrogenated oils, and or lard. Also You need to filter better. If you use the good oils from restaraunts, it will mix properly, however, a Powerstroke is not going to run good on it, you need to find a non electronic engine, or make biodiesel, or get some sort of fuel heater and it will run, Heating to 180 as some say is not necessary, however the oil has to be warm
__________________
1988 F350 7.3 Crew Cab 4x4 Dually C6
1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual.
  #9 (permalink)
Old 03-11-2008, 05:24 PM
1994diesel's Avatar
ok my i heat up the oil then run it through filters, thats what i meant by it evaporating when i heat it up not running it through the engine, and secondly my truck is not a powerstroke, its and idi, which means its not electronic, thanks for giving me links to sites
__________________
Justin
  #10 (permalink)
Old 03-12-2008, 02:03 AM
1994diesel's Avatar
ok i want to THANK YOU guys for helping me out, i didnt realize what that was doing to my truck and the process to do it properly, i did a lot of research!!! lol and i now know why and what to do, sort of, so im going to do my first dr.pepper test batch, wish me luck!!!
__________________
Justin
  #11 (permalink)
Old 03-12-2008, 02:12 AM
1994diesel's Avatar
__________________
Justin
  #12 (permalink)
Old 05-01-2010, 01:38 AM
SCROWLEY707's Avatar
SCROWLEY707 SCROWLEY707 is offline
SCROWLEY707 is starting off with a positive reputation.
If I was you I would drop your tank(s), I believe you have screens on your fuel pickup and if your oil was not properly filtered and being partially hydrogenated, the oil will thicken and settle to the bottom of your fuel tank clogging your pickup screens. It happened on my truck just from the small amount of oil in my return line each time I purged my truck, a problem that I have now fixed with a time delay return valve and the in-tank mod on my truck. but my truck is a powerstroke. letting oil sit for a month is a good way to settle the water down to the bottom, then pour the good oil off the top.
  #13 (permalink)
Old 05-01-2010, 02:02 AM
binuya's Avatar
binuya binuya is online now
binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.
This thread's 2 years old. I hope he got his truck and process straightened out.
__________________
2001 F250 7.3 CC SB 4x4 Lariat
S&B Intake, MBRP 4" Turbo Back, HPX, AIH Delete, Hutch and Harpoon,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard, Fumoto,
Homebrew American Biodiesel (B100 whenever I can)
1995 Mercedes Benz E300D, 2004 Mercedes ML350
Tags
73, add, blend, diesel, f250, f350, ford, heat, litre, oil, run, truck, turbo, veggie, vegitable
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
