5th Wheel Vs. Gooseneck. - Ford Truck Enthusiasts Forums
Old 03-09-2008, 11:01 AM
RogueSpear2023's Avatar
RogueSpear2023 RogueSpear2023 is offline
RogueSpear2023 is starting off with a positive reputation.
I have been wondering this for quite a while so I thought I would ask. I would like to know the difference between 5th wheel and gooseneck. I know the visual differance, but the actual load carrying and why most horse trailers and flat bed trailers are gooseneck, and campers are 5th wheel? Does 5th wheel offer better stability? Maybe a pros and cons list to each? Are there any campers that are gooseneck? Thanks.
Old 03-11-2008, 10:45 AM
bump I know some one nows this.
Old 03-11-2008, 10:56 AM
icrman icrman is offline
icrman is starting off with a positive reputation.
The gooseneck is more unrestrained, free to twist more, like if you have one side go over a high object, that side will be free to move up, where on a 5th wheel the hitch resists it as it does not float much that way.
If you install a hitch the goose neck one will leave the bed of the truck fully usable.
B&W turn over ball gooseneck hitch has an adapter for a 5th wheel if you need a 5th.
Old 03-11-2008, 11:38 PM
mudmaker's Avatar
mudmaker mudmaker is offline
mudmaker has a very good reputation on FTE.mudmaker has a very good reputation on FTE.mudmaker has a very good reputation on FTE.
A gooseneck will carry just as much wieght. The reasons most horse trailers and flatbeds use them is due to what icrman said, but the is also the reason they are not used on high profile vehicles, such as rvs. They do not offer as much stability on higher CG trailers. That is where a 5th wheel hitch is much better. I also like it better on my 43' long flatbed because of the long frame. The 5th wheel doesnt allow as much twisting movement.
Old 03-12-2008, 09:38 PM
99whiteford's Avatar
99whiteford 99whiteford is offline
99whiteford is starting off with a positive reputation.
I have a double pivot Fifth hitch .I have never had any problem with side to side restriction or binding.Also the fifth wheel hitch is much easier to hook up.With the gooseneck you have to line hitch up directly over the ball.With my fiver,,If you are close it will slide it right into place.
gooseneck hitch -buying a 5th wheel camper cornell5 1999 to 2016 Super Duty 12 03-26-2015 11:18 AM
Gooseneck ball vs 5th wheel plate Beechbum Fifth Wheel & Gooseneck RV Towing 7 02-10-2015 11:46 PM
2012 F350 5th wheel hitch/gooseneck erics218 Fifth Wheel & Gooseneck RV Towing 7 02-05-2012 06:57 PM
5th wheel or Gooseneck wingerpaul 1999 - 2003 7.3L Power Stroke Diesel 23 07-24-2008 06:58 PM
Difference between 5th and gooseneck?? mongo75 Fifth Wheel & Gooseneck RV Towing 19 07-08-2007 12:54 AM
Tags
5th, cons, diference, difference, goose, gooseneck, goosneck, hitch, neck, pros, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
