any !. Well the 87 up will have efi friendly cam. But the 93 down 302 had old order where your 302 has same as 351. So you would have swap cam or repin or rewire injector harness. If its a MAF there be few more. I have a 93 in a 94 .
So if want plug and play find a 94 and newer.
__________________
Red Neck rule #1 If you drive a truck you should always be looking for trucks to get parts off of. If you can't find part used you aren't looking hard enough.
__________________
guess what i need to know is if i find a 87 or new engine (basic long block) it should bolt up the the overdrive trans and the stock accessarys should fit.
any help is good
Yes.. any 302/5.0 block will bolt up, and any '87 or later block will be compatable with the stock Ford roller cam assembly in your '94 block. If you don't get a late model block it's not the end of the world though, there are lots of better-than-stock cams in both flat tappet and roller versions that are also compatable with the stock EFI system, and if your truck is mass air you have even more cam choices.
i just put a engine in my truck and i have two dead cly. number 6 and 8
i check the compression its around 120, checked the injector wire and one side flashes with a test light hooked to the pos side of batt. the othe side of injector is on all the time with the testlight grounded. i put air preasure in all the left bank cly. and no leaks in the intake or the exhuast. i have good spark at the cly. i swicthed the injectors from the good cly 5 and 7 and put them in the 6 and 8 spot and still no luck
this thing should run but it dont
HELP
The cylinders won't fire because of no fuel or no spark. If the injector is OK, (check by swapping them with another cylinder) then it must be spark. Check proper wiring, wire routing, plugs, everything. Hopefully the block came from a truck and not a car. If it came from a car, you have the wrong firing order.
1993 F150 302 somesortofautomatic. F350 front springs, bed liner, tool box, ugly tail gate. One thing you can say about a F series truck is it's as aerodynamic as a brick, turned sideways.
Yes i think it did.
So im thinking the firing order would have to be the 15426378 and i would have to make the injectors fire in the same sequence.
Am i thinking in the right direction.
If not then what
What??? Did your engine come from a car or truck? If from a car, just change the cam BUT, the year engine is important anyway because of of other things like pistons and heads.
Is your '94 truck mass air by any chance? If your truck is speed density it fires the injectors in batches of 4 and the cam firing order won't matter. If it is MAF it fires the injectors sequentially in the 13726548 sequence, but the cam in the CV motor has the 15426378 order, so you need to change one or the other. I'd suggest changing the cam as the stock CV cam is pretty sad anyway.
You are using the truck computer with this too aren't you?
