5w20 Oil
on
5w20 Oil
Most of the time, I get the oil changed at the dealer & they use Motorcraft 5w20 semi-synthetic in bulk. My corner garage carries only Quaker State 5w20 but it is not semi-synthetic, just plain 5w20 oil.
Would I be asking for trouble if I let the guy at the corner do it with the Quaker State once in a while when it is convenient, and then at the dealer with Motorcraft again when having other service done? eg. OK to alternate?
Any issue with this or am I worried about nothing?
Originally Posted by JimTex
I will never change the type of oil. The dino would be fine if that was what i started with, but if I started with the blend, i would stay with it. My dad was a mechanic and something he instilled in me, right or wrong.
The engine doesn't know the difference if it is clean, the proper weight and meets the manufacturer's recommendations.
Mobil1 is available in 5W-20. I've seen it on the shelves at Auto Zone and Wal-Mart.I use the Motorcraft 5W-20 Synthetic Blend with a Motorcraft FL-820S filter. I did, at one point, have to substitute a conventional 5W-20 because the Motorcraft oil wasn't on the shelves where I usually get it. It was a nice weekend day and it was time to change the oil. I don't know if it was just my ears but after changing the oil with the conventional, I noticed the valvetrain clatter was louder than usual on start-up and it didn't go away right away once oil pressure built up. I changed the oil shortly after that and put the MC Synthetic Blend back in it (back on the shelves) and the clatter went away.
Mobile 1
I buy the Mobile 1 synthetic 5W-20 from walmart, i am actually really happy because they just started carrying the 5 qt jugs. they used to carry all of them except 5W-20 in the 5qt, but they finally got it. It saves me about 5 dollars each time i buy one. I usually buy 1 when i have the money because that crap is so expensive and that way when it is time to change the oil i have 2 or 3 5qt. jugs in the shop ready to go! I love the synthetic, it might be overkill but so are all the other preventive maintenance things i do to my truck
