Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 03-08-2008, 08:48 PM
Tom D Tom D is offline
Garage is empty, add now
Tom D is starting off with a positive reputation.
Smile First Batch
Well, I have FINALLY completed my "open barrel" BD processor with a LOT of help from Fabman. Before going great guns with a full batch, I am going to make a 5 gal batch in a small drum with a paint mixer and drill motor.
My question is, I did a titration on the WVO I got from a friend's restaurant. The results were as follows. It titrated to 2ml of KOH/H2O which equates to 2 extra grams of KOH per liter of WVO in addition to the base 7 grams per liter. This means if I use 9 grams of KOH per liter I should be OK. Of course I am still going to abide by Don's suggestion of watching for the mix to turn "tar black or else add more KOH. Do I have this right? If all goes well, I will run a full batch and also post pics of my portable (trailer mount) BD processor. Tom
__________________
93 F-250 7.3 Banks turbo, 3.5" exhaust 4" ram air K&N filter E40D 4.10. Pyro, boost, & tranny temp gauges. Tru Cool 28,000 GVW trans cooler. 100% BIO
  #2 (permalink)
Old 03-08-2008, 09:20 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Good for you Tom! I knew you could do it! One thing tho, you should use 7.8 as your base amount if your KOH is 90% pure.
I can't beleve your going to do a small batch first. When I made my first batch I built a 100 gallon appleseed style processor and filled it up for the first batch................wound up with 100 gallons of "glop" Ok, maybe a test batch first is a good idea
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 03-08-2008, 11:35 PM
evictorwalli's Avatar
evictorwalli evictorwalli is offline
evictorwalli is starting off with a positive reputation.
Yeah!!! I hope I am not too far behind you...
__________________
Eero
1988 F-250 4x4 7.3L 5Spd XLT SC LB K&N AF 150,000M Great Shape Super Clean Project Truck
1988 F-250 4x4 7.3L 5Spd XLT SC LB K&N AF 286,000M Beach/Wood/ Hunting/Fishing/soon to be parts truck
2005 AWD Freestyle Bride's Rig
  #4 (permalink)
Old 03-09-2008, 12:52 PM
I don't know what the purity of the KOH is. (I bought it on EBay from a guy who goes by Dudanation) Don't know whether you know of him. If there is a question of purity, I should probably go with your suggestion to be sure.
Another question I have. In one post you (or someone else) said to use 5 gal methoxide for 25 gal WVO. In another post, (this one by you) it states that you put 50 gal of oil in the mix tank and add 5 gal methoxide. I don't know which recipe to use. Please enlighten me. Thanks Don
__________________
  #5 (permalink)
Old 03-09-2008, 01:40 PM
1935 Ford pickup
You need 20% Methoxide. a 25 gallon batch needs 5 gallons, and a 50 gallon batch needs 10 gallons.
__________________
  #6 (permalink)
Old 03-09-2008, 02:17 PM
Thanks Don. I'll let you know how the test batch comes out. I'll either burn it or use it to fix the leak on my roof. The former is highly preferred. Tom
__________________
  #7 (permalink)
Old 03-11-2008, 11:09 AM
Sure glad I only did a small batch. I have 20 liters of brown "gook" I have seen this on other posts so I must have made a classic mistake.
Here are the particulars; All measurements were precise.
20 liters WVO (titrated to 2 grams plus 7.8 base grams KOH)
Heated WVO to 150 Deg. Added 1 gal.Methoxide and proceeded to mix.
Mixture was not tar colored as you mentioned so I added 1 gram KOH.
No change in color but proceeded anyway.
Let separate 12 hours-medium brown gravy that looks like someone didn't mix the flour in properly when they made the gravy.
Mistakes I could have made: WVO was not maintained at 145 deg during mix (130 at best)
I dumped methoxide in all at once, then started mixing.
Inside of container was painted and it started peeling off. (I filtered before going to separater. Any suggestion will be greatly appreciated. Tom
__________________
  #8 (permalink)
Old 03-11-2008, 11:11 AM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
Yeah I remember my first batch, I made a 100 gallon setup, then decided to do a "SMALL" 40 gal test batch, and wound up with 40 gallons of "GLOP", it makes me laugh to see how far I've come in a year and half, I've already threw 2 reactors away and build new, more efficient ones.
__________________
1988 F350 7.3 Crew Cab 4x4 Dually C6
1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
