When did 5.0 roller engines start?
I've got a 5.0 EFI coming from a salvage yard for my 1994 F150. Its a truck engine according to them. I didnt ask what year it was from, according to them it is the engine for a 1994 f150. I didnt ask what exact year truck it was from. Now I'm wondering what year the engine is and if its a roller motor. What year did the 5.0 truck engines start as roller motors?
I will tell you anouther thing to look for, the knock sensor hole. Trucks and vans have this provision. All others did not. The hole is located right behind the intake manifold. it is a blind hole,which means is does not go all the way though the block. It stands stright up. If the block in question does not have this hole you will not be able to hook your knock sensor up causing your check engine light to stay lite. Also, you cant drill and tape this hole,there is not enough material, the block will crack, the hole is pipe threaded.
One way to tell if its a roller block is to look at the lifter valley, it should have the two small,taped holes, for the lifter spider. To some it up, look for the hole, look to see if it has the provision for the spider.
I have a 92 that needed a motor, I started with a bare block, mine was cracked. I did not know about the knock sensor issue,but I do now, almost used a GT block. I hope this helps you out.
The roller block casting numbers are: E7TE, E6SE, F1TE. Might be more too. As mentioned before, the roller cams went into the trucks & vans in 1992 model year, before that, they had a roller block (starting in 1986) with a flat tappet cam. If you now have a 94 truck, you'll need to make sure the replacement engine has the 94-up F4TE cam.
Some of the roller blocked truck/van 5.0's that had flat tappet cams didn't have the lifter valley retainer bolt bosses drilled and tapped, some even didn't have the bosses fully cast, I have one of these, the bosses are there, but not fully formed. The last two blocks like this I've aquired, one had the bosses drilled and tapped (but plugged with carbon gunk), the other had the "half-cast" bosses. One was an 88 block, the other an 89. Ditto on the knock sensor hole too, mentioned by 60oneton, although I think you can drill and tap this on any of the blocks.
on
Originally Posted by Hillcapper
F1SEBB12 also there is a second number - 4029
They came off the block in the general vicinity of where the starter would be (if it had a bell housing). When I run these numbers it shows from a 1991 T-Bird! I would like to think Planethax is right but there is no other indication this is a Cobra engine. Help! Do I keep it or send it back?? Paul?
I used this site
http://reincarnation-automotive.com/...explained.html
I used this site
Still googling, seem to find different info at every turn.
Last one i found was actually from this site
https://www.ford-trucks.com/forums/2...-block-id.html
Originally Posted by n2o88
Casting number is the same for multiple years after the first year it comes out....so F1SE is used for 91 up past your 94. F1SE is a roller 302 block, basically identical to all 85-93 mustang blocks.
