What is the difference in the headers for the 2Wheel drive and the 4Wheel drive and will the 2Wheel drive fit the 4Wheel drive 300 I6? Thanks in advance
As far as anyone here has determined they are the same on the later model trucks. As long as you don't have anything 4x4 related sticking out the passenger's side of the trans you'll be fine.
When I was comparing the two versions the only real difference I could find was the difference in primary tube diameter and flange thickness. I assume that the clearance issues are the same on a F150 as they are on the F250 (which is what you asked about in your other thread)? I have an old post that is called 2wd or 4wd header and got some good advice from other members if you can find it with the search function, which is not always the easiest thing to do!
