Windshield Wipers
also, to the best of my knowlege the wiper wiring runs from the motor to the switch with a feed to the fuse box...seems odd and I know mine isnt like that but I recall pulling one apart like that...odd indeed.
Also, the 65 and 6 switches were different in regards to the washer switch as the 65 has the button above the ignition switch and 66 was a pull on the wiper switch as I recall. I believe thats for 2 speed wipers...single speed Im not sure about.
- cs65
- cs65
Also, the 65 and 6 switches were different in regards to the washer switch as the 65 has the button above the ignition switch and 66 was a pull on the wiper switch as I recall. I believe thats for 2 speed wipers...single speed Im not sure about.- cs65
1965/66: Foot pump = manually controlled = pump the pedal...Voila!
1965/66: Foot pump, electrically operated...one or two taps on the pedal is all it takes.
The manually operated pump was a dealer installed accessory.
The electric version was either factory or dealer installed.
Then there's this one..
1966 factory installed = Button on dash.
There's no mention of a wiper switch being used for the washers, too.
Originally Posted by 64F-100
I have to agree with using rain-x...I used to think that stuff was BS until I got my latest car; the PO used rain-x on the windshield. I've driven through some decent downpours and never even turned on the wipers...
Jowilker will know, he's damn near as old as I am.
Ppl rubbed cut plug chewin' tobacco on the glass.
The water slithered right off.
What did ppl use in the old days before Rain-X?
