Windshield Wipers - Ford Truck Enthusiasts Forums
Windshield Wipers
Old 03-08-2008, 12:58 PM
matt2491's Avatar
matt2491 matt2491 is offline
matt2491 is new and has a neutral reputation at this point.
Windshield Wipers
Were they two-speed? And how do you adjust the speed? Someone ripped the windshield wiper wiring out of my truck, so I can't just go look. And I'm trying to get them working again.
Driving around in the rain without windshield wipers is S C A R Y ...
Old 03-08-2008, 01:00 PM
FitchBanjos's Avatar
FitchBanjos FitchBanjos is offline
FitchBanjos is starting off with a positive reputation.
My 66 CC has 2 speed wipers. The switch has 2 positions.
Old 03-08-2008, 01:10 PM
Customcab's Avatar
Customcab Customcab is offline
Customcab has a very good reputation on FTE.Customcab has a very good reputation on FTE.Customcab has a very good reputation on FTE.Customcab has a very good reputation on FTE.
Not all models had two speed wipers; I've only own 64- 66 models with only 1speed; That's one feature I would love to upgrade too. But my current 65 is only a show & shine type driver. Not a daily driver.
Mitch
Old 03-08-2008, 02:33 PM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Have you tried RainX?
I have a 2 speed from a 76 and delay from something later. You can swap motor and switch from a two speed while retaining the original arm on the end of the motor, if you want it to park correctly.
John
Old 03-08-2008, 04:14 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1961/66: One speed wipers were standard, two speed wipers were optional.
Old 03-08-2008, 04:26 PM
matt2491's Avatar
Gotcha. Thanks guys for the info.
Old 03-08-2008, 05:35 PM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
also, to the best of my knowlege the wiper wiring runs from the motor to the switch with a feed to the fuse box...seems odd and I know mine isnt like that but I recall pulling one apart like that...odd indeed.
Also, the 65 and 6 switches were different in regards to the washer switch as the 65 has the button above the ignition switch and 66 was a pull on the wiper switch as I recall. I believe thats for 2 speed wipers...single speed Im not sure about.
- cs65
Old 03-08-2008, 07:41 PM
Quote:
Also, the 65 and 6 switches were different in regards to the washer switch as the 65 has the button above the ignition switch and 66 was a pull on the wiper switch as I recall. I believe thats for 2 speed wipers...single speed Im not sure about.- cs65
1965/66 w/wiper washers came several ways.
1965/66: Foot pump = manually controlled = pump the pedal...Voila!
1965/66: Foot pump, electrically operated...one or two taps on the pedal is all it takes.
The manually operated pump was a dealer installed accessory.
The electric version was either factory or dealer installed.
Then there's this one..
1966 factory installed = Button on dash.
There's no mention of a wiper switch being used for the washers, too.
Old 03-08-2008, 10:40 PM
daveengelson daveengelson is offline
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Here's an article from FTE forum may find helpful.
http://www.ford-trucks.com/article/i...rd_Pickup.html
Old 03-09-2008, 09:34 AM
64F-100's Avatar
64F-100 64F-100 is offline
64F-100 is starting off with a positive reputation.
I have to agree with using rain-x...I used to think that stuff was BS until I got my latest car; the PO used rain-x on the windshield. I've driven through some decent downpours and never even turned on the wipers...
Old 03-09-2008, 09:38 AM
Quote:
What did ppl use in the old days before Rain-X?
Jowilker will know, he's damn near as old as I am.
Ppl rubbed cut plug chewin' tobacco on the glass.
The water slithered right off.
Old 03-09-2008, 12:07 PM
Customcab's Avatar
I'm to cheap for those high dollar products, like rainx; I always use the old paste wax on the outside of my window's; you still need your wipers but it does make the water run off easier.
Mitch
Old 03-09-2008, 12:41 PM
gezn2 gezn2 is offline
gezn2 is starting off with a positive reputation.
I ran across a story once about streetcar motormen using a muslin bag of Bull Durham, the oils from the tobacco apparently did the trick
Old 03-09-2008, 01:18 PM
jowilker's Avatar
Quote:
Hmmmm, Bull Durham was a fairly dry smoking tobacco, wonder what oils?????
John
Old 03-09-2008, 02:30 PM
matt2491's Avatar
Wait a minute, what is "Rain X" again? Some sort of material, when applied to the windshield, that allows the rain to slide right off it without wipers??
Tags
bull, cleaner, durham, tobacco, windshield
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
