royal purple
Originally Posted by PW01
I guess that I will be unable to back up my post. The "search" feature on BITOG is near worthless.
I have seen enough raw dyno charts to understand how they could be used in a "less than completely honest" manner. We had engine dynos in engineering school. Charts must be corrected to standard conditions, temperature, humidity and barometric pressure, (density altitude) to be of any value.
Jim
Jim
If they dyno tested 2 oils right after each other, that should normally mean that the environmental conditions are the same (not that someone couldn't cheat on them, however) and the 2 likely factors could be the oil temperature and weight. If someone wants one oil, i.e. a 10w30 come out ahead, just test it against a 20w50. Or one oil is tested cold while the other is tested warm.
