EGR Valve location
03-07-2008, 02:19 PM
on
EGR Valve location
Can anyone point me toward the EGR valve on a 93 3.0L? I looked around and can't find it.
Thanks
Doug
03-07-2008, 02:43 PM
on
My 93 4.0 didn't come with one. Maybe your 3.0 doesn't either.
03-07-2008, 02:59 PM
on
There is no EGR on a 93 3.0L.
03-07-2008, 03:47 PM
on
I am getting a studder on hard acceleration and I notice the IAC is getting fouled every couple of months. My guess was the EGR. Any ideas?
Doug
03-07-2008, 10:32 PM
PCV valve would cause the IAC to foul up. If you haven't replaced the PCV recently, I would do so.
03-08-2008, 02:43 AM
The gases that get sucked through the PCV valve are generally blow-by from the cylinders. If you're seeing a lot of fumes coming from the PCV hose, you may have very worn rings. Is your engine burning a lot of oil?
03-08-2008, 12:30 PM
on
I replaced the PCV valve about a year ago. I don't know if I am burning oil since I have slight leak from the rear seal.
Bently_Coop
Modular V10 (6.8l)
23
06-16-2019 10:04 PM
doug42190
06-10-2016 10:25 AM
duggy2145
10-23-2015 10:14 AM
nowsthetime3.0
05-11-2015 11:30 PM
comertrucks
02-08-2004 07:56 PM
