Oddometer/Speedometer vs 20" tires
Originally Posted by Twinsdad98
no, it's done through sensors so you needn't worry. I run stock 18s in winter and 20s summer. Speedo has always been correct
305/50/20 = 32.01 inches
275/65/18 = 32.07 inches
Originally Posted by edmundo7
All,
I had a question regarding the Oddometer/Speedometer and the 20" tires. Will putting smaller tires on the F150 increase the reading on the Oddometer? If so, do I have to take it into the dealership to adjust?
Thanks
Ed
Thanks
Ed
also, this site helps calculate the tire difference: http://www.miata.net/garage/tirecalc.html
You might want to do a few searches as well, this comes up pretty regularly....kind of like this one from last week....
https://www.ford-trucks.com/forums/7...ire+gear+ratio
That's not entirely true. The series of computers that control your drivetrain rely on these readings for many things--not just to display speed & calculate miles traveled. Tire swaps can lead to automatic transmissions not shifting correctly & your ABS not operating optimally.
The larger the change, the larger the impact.
