Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2004 - 2008 F150
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-06-2008, 06:04 PM
champaroo is starting off with a positive reputation.
help with 6'' lift
i am installing a procomp 6'' stage II lift on my 07 f150 4x4 do i need the emergency brake bracket i cannot find the one that suppose to come with the kit?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-07-2008, 12:19 AM
mattd17's Avatar
mattd17 is starting off with a positive reputation.
if you dont use the aftermarket bracket, then when you install the larger lift in the back, it will pull on your e-brake and keep it constantly set (not completely, but you will definately hear it rubbing). that is why the kit comes with a bracket to lower the cables so they dont pull. if you just left them out of the backet, then it wouldnt rub, but i dont know how well the e-brake would work when needed..... but for now i would say to do that, and then as soon as you can i would install the correct bracket.
__________________
2006 F150 SCREW 4X4 5.4..... Magnaflow SISO, Edge Evolution Programmer, 6" RCD Lift, 1.5" lift shackles, 35" Pro-Comp Mud Terrains, ProComp 9047 wheels, Fire and Ice LED bar, Under hood engine lights, Glove box lamp, Dual style Fog/Driving lamps, Recon smoked cab lights.... Who know's what next ??!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
