Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-06-2008, 05:58 PM
tiger13e is starting off with a positive reputation.
boss 302 intake vaccum question
I built a boss 302 engine, it is a 302 block with a set of 4 barrel cleveland heads on it. The heads have the big valves, it has a factory aluminum dual plane boss 302 intake on it. It has a factory set of boss 302 cast exhaust manifolds on it, 750 double pumper holley carb, lost the cam card so I don't know what size it is, bored .60 over with flat top pistons, stock rods and crank. The problem I have is that I mud race this Bronco and the rule states that you need to pull 17" pounds of vaccum at 900 rpm's to run in the stock class. I can move up a class and then I need to pull 12" pounds of vaccum at 900 rpm's. The rule makes me run cast exhaust manifolds also. I did a vaccum check on the engine with all vaccum lines pluged and it pulled 8" pounds at 900 rpm's, nice. The short stroke 302 and big port heads are not known to pull vaccum. So what I need is someone that has built one of these to hook a vaccum guage up and tell me what it is pulling for vaccum, and let me know what the cam size is. Please help!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-07-2008, 09:11 AM
job1bf is starting off with a positive reputation.
a custom cam will likely solve your problems...i read lots of stories about "vacuum' rules and that seems to be the best way to meet the rule.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
