6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Underhood Pics.
Old 03-06-2008, 12:06 PM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
Underhood Pics.
Hello guys. This might sound strange but, do any of you have underhood pics you could post on here. I would like to see the new engine without having to go to the dealer to look.
Thanks.
Old 03-06-2008, 02:11 PM
cleatus12r's Avatar
cleatus12r
cleatus12r is offline
Butt-Head
Received 1,972 Likes on 1,107 Posts
Trust me, you don't want to even accidentally see one. Seriously. If you value your sanity, forget you asked!! I first saw one about 2 weeks ago. It was on my alignment machine and I HAD to see the engine compartment. I wish I hadn't seen it. I have had GRUESOME nightmares ever since.
Old 03-06-2008, 02:22 PM
miller_feed
LOL Cody, I just wanted to see how far back it sits to have to pull the cab to work on it. I do all the work on mine so I was wondering. Mine it tight doing turbo stuff but it can be done.
Thanks Cody, Don't guess the 6.4 guys will talk to a 7.3 guy. Plenty of views.
Old 03-06-2008, 03:18 PM
F0rdFre@K's Avatar
F0rdFre@K
F0rdFre@K is offline
I'll talk to anyone who'll listen. usually no one. But, no pics of under my hood.... sorry!!!
Old 03-06-2008, 04:05 PM
SUPERDUTY_untouchabl's Avatar
SUPERDUTY_untouchabl is offline
It sits pretty far back. Sadly the turbos are at the back of the motor (you can see them though). As far as work on them goes, I highly doubt you would even want to attempt to work on them without removing the cab. But if you have the patience and small hands I guess you could.
Old 03-06-2008, 05:56 PM
DieselWhisperer's Avatar
DieselWhisperer
DieselWhisperer is offline
Well, I've got news about the turbo work/cab off deal. I took my truck in Tuesday a week ago to have an oil pressure sensor replaced (was getting a CEL). The service writer said they would have to remove both turbos to get to the sensor. I said woah! That's a cab off job isn't it? He said no, he didn't think so but he'd check with the diesel tech. Diesel tech said no also. Anyway, brought the truck in at 8am, sat in the waiting room until 930am and the service writer came in and apologized. He said they had the wrong part and the tech was putting my truck back together (putting the turbos back on). So I had to wait until this past Tuesday and they did get the right part and everything went well. Total time was about 2 hours. Now, I said all that to say this. I called another diesel tech at another dealer and asked him about having to remove the cab to work on the turbos and he said... at first it was a cab off repair but someone came up with some type of tool to get the turbos off without removing the cab. The reason for this was that lots of construction guys were welding on ladder racks and things like that and they would have to cut off the racks before they could remove the cab. I don't know if he was just blowing somke or not, but thought I'd pass on what I was told.
Old 03-06-2008, 07:23 PM
randomhero1172's Avatar
randomhero1172
randomhero1172 is offline
http://www.bligblog.com/media/06-13-...450-02_450.jpg
http://www.performanceoiltechnology.....4L_engine.JPG
http://www.afefilters.com/productreviews/54-31262-08FordPowerStrokeV8-6.4L(td)/images/aFe-system-installed.jpg
http://images.fourwheeler.com/roadte...uty+engine.jpg
DEAR GOD CODY WAS RIGHT. Talk about trying to fit 10 Lbs of ...CRAP...Into a 5 LBS Bag ! Thats scary
Old 03-07-2008, 03:14 AM
LvTitan's Avatar
LvTitan
LvTitan is offline
it's a nightmare for sure.. i think you might have to even pull the cab to check the dipstick ! ! ! ! !
there's not even room to drop a french fry in there, it would never make it to the ground..
i'd HATE to have to work on one unless it was on an engine stand in front of me ! ! !
Old 03-07-2008, 04:15 PM
miller_feed
That way funny Joe. Yeah Danny, it looks so tight in there compared to my 7.3. I can't amagine a tool to take that turbo off. It must look like the old CRAZY STRAWS. LOL
Thanks guys for the come back.
My 01'.
<CENTER></CENTER>
Old 03-11-2008, 06:24 AM
Crodad's Avatar
Crodad
Crodad is offline
Here are a couple of under the hood pics of my truck.
Old 03-11-2008, 08:23 AM
20046.0PSDX's Avatar
20046.0PSDX
20046.0PSDX is offline
It may be shoe horned in (w/ a little Astroglide to help ) but all I see is POWER hidden under all that other stuff!!!
Stay Tuned
Amp
Old 03-11-2008, 01:04 PM
SANDDEMON08's Avatar
SANDDEMON08
SANDDEMON08 is offline
I know here localy the dealer can remove the cab in 20 minutes. I watched them do it and it is impressive. The 08 cab's were designed to be removed for most repairs unlike the previous SD's.
Old 03-11-2008, 06:58 PM
BobsF350's Avatar
BobsF350
BobsF350 is offline
its an engineering marvel
Old 03-11-2008, 07:25 PM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Received 3,392 Likes on 2,089 Posts
To remove the turbo charger with the cab on you have to use a lifting bracket which is designed to not damage the seal between the high and low pressure side. The turbo charger when lifted has to be kept level as not to damage the oil drain tube.
Old 03-12-2008, 07:24 AM
surf_ox's Avatar
surf_ox
surf_ox is offline
one good thing about our 6.4L engines...if you drop a tool while working on them it wont make it to the ground....theres little to no room to see daylight much less have an adjustable wrend fall on the ground via the engine compartment.
bwahahahahahahahaha
Quick Reply: Underhood Pics.
