boost gauge bounce
Old 03-06-2008, 08:50 AM
wmiller's Avatar
wmiller
wmiller is offline
boost gauge bounce
My boost gauge is steady up to 10 lb than bounces around 10-15 lb then is steady till 20 and bounces a lot up to 25. Is this normal? turbo issue? or just plumbing?(i have t in map line)
Old 03-06-2008, 10:26 AM
FARM69's Avatar
FARM69
FARM69 is offline
Boost gauge bouncing is fairly common because you tapped into the map sensor line. The map sensor releases a little bit of air, hence the bouncing. Try to move your boost gauge closer the the intake on the map line. That may help.
Old 03-06-2008, 11:44 AM
Neal 97 250's Avatar
Neal 97 250
Neal 97 250 is offline
Also check to be sure there are no kinks in the line.
arkredneck
12-16-2013 01:14 PM
dieselsmoker
04-09-2011 11:29 AM
sean23johnson
44
01-09-2007 10:54 PM
poulin15
01-30-2003 08:30 AM
unioncreek
01-07-2002 10:19 PM
Quick Reply: boost gauge bounce
