You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Check with the mounties or local laws before doing such a swap as it will negate the VIN numbers and title for the truck.
There are many options for modern suspensions on the older straight axle trucks.
Garbz
__________________
98 528I BMW
64 F100 "Christine II" 390 NP435 6" lifted 2 wheel drive
63 F100 Uni Custom under construction 4" off the pavement and built to drive.
69 M250 Crew Hiboy 472 C6 Ranger, getting a full rebuild.
There is no law for frame swaps.I am woundering the easy way of doing this or what type of frame can i use.Mainly i want to change the front suspention to update brakes and power steering.
I think the easiest way is to use a 79 F100 4x4. Replace the uni floor (Cab portion) with the floor from the 79. Fabricate the rear cab and bed mounts to adapt the uni body to the 79 frame. None of this is going to be easy. The cab floors are very similar on all 61-79 Ford trucks. Using the 79 floor gets you front cab mounts that bolt to the 79 frame. Fabbing rear cab mounts out of 1x2 tubing is not complicated. I have not done this swap but I intend to do it when I find a suitable Unibody truck. I have a source for a 61 uni long small that I may cut up just to see if this will be feasible. I saw a short uni on a 79 4x4 frame in Georgia. That truck looked so stock I went and spent abkout a hour looking at it. He used all the 79 running gear. IMHO this id a dooable deal!
__________________
William in Atlanta has retired to St. George Utah!
No! You are going to set the wheelbase of the newer frame to match the wheelbase of the Uni. So it doesn"t matter what frame you use. When I do frame swaps I take both the old and the new to the welder and he matches up things like cab mount points and wheelbase. Then I do the sheetmetal. I like swapping in complete new floors because it is the easiest way to get cab supports to line up.
__________________
