Passenger side window stuck open...
My passenger side window is stuck open on my 93, its got the power windows. I know its the motor that is shot and not the switch or a fuse. I'm wondering, since i cant afford a new motor for it at the moments, if there is a way to manually get the window up. Anyone have any idea? Thanks
The motor runs, but the window doesn't move.
The gear kit is available from auto parts stores and Ford: D0AZ-62234A24-B
Disconnect (unbolt) the plastic window roller from the end of the regulator arm. Then...push the window up, re-attach the roller to the arm.
The roller has a stud on it that bolts to the end of the arm, the roller portion fits into the window channel that's bolted to the glass.
btw: These rollers break all the time...its flexible metal stud is pressed into the plastic roller portion, and pulls out...if the roller breaks, the window won't move.
E9TZ-1023240-A .. Window Roller
selorentz
04-16-2002 01:16 PM
