Longbed to Shortbed conversion
Working at a body shop for some years we did do sevaral frame section repairs. It is very safe if done correctly, in fact that is exactly how the frames are put together from factory. I have never shortened a wheelbase though but have seen it done to a few.
With this job you will need to remove wiring harness, brake line to the rear, all fuel lines and any other line that is run along the frame rail before you cut/weld. These will all need to be shortened before reinstalling. Aside from that, a shorter drive shaft and a bed you will be good LOL
Shortening the frame is not as huge of a process as it looks. Done properly (fish plates on the back side) the welded section of frame is even stronger than the original. It's done often in the hot rod world with great results.
But, I'm with the others here. Why would you want to go to the hassle? Are 2000 F-250 CC short bed trucks that rare?
And CC short beds are everywhere around this area. Try to find one with a long bed is 10x harder.
