Different part #'s for 150 & 250???
My Dad has a 2004 F250 V10 Super Duty. I have been given the unfortunate honor of putting new mirrors on it. They have no puddle light and they retract manually. They do have the power adjust, heat/defrost, & turn signal. The truck did have power adjust mirrors from the factory and we are adding the turn signal & heat. The wires are there for both the heat & signal. I gather from the 8 pages that I will have to change the heater control head, change the fuse block on the passenger side kick panel (or glove box?) and add a relay of some sort. Which heater control w/rear defrost button do I need: 7L3Z-19980-D or 6L3Z-19980-CA?
There appears to be some confusion generated because I believe there is a difference between the F150 & the F250 Super Duty? Can some someone explain the difference between the mirrors and give some part numbers for both types? I do apologize for my lack of knowledge about Ford trucks ...that is why I am here!
Thanks, Shimaze
