Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #91 (permalink)
Old 09-24-2008, 09:35 AM
TascaFordParts's Avatar
TascaFordParts TascaFordParts is offline
SPONSOR
TascaFordParts is starting off with a positive reputation.
The truck requires a new Fuse block. There is a relay and fuse that you need to install and your truck probably does not have the connectors setup on the block. I think they go for around $140 or so.
  #92 (permalink)
Old 09-24-2008, 12:47 PM
rceagle1a rceagle1a is offline
rceagle1a is starting off with a positive reputation.
Ok on the fuse block but what about the Temp control not being right? Can I change the pin assignments to make the air direction knob right?
  #93 (permalink)
Old 09-24-2008, 01:01 PM
SPONSOR
If you get me an email address I can send you a break down of the connector and what all the wires are for.
  #94 (permalink)
Old 09-24-2008, 01:58 PM
Hey thanks! My email address is rceagle1a@iowatelecom.net. Could you send me the diagram for both the 2004(Mine and the 05-06(New control) I am comfortable changing the wire locations to correct the air flow issues. Thanks a ton man!!!! Awesome Service Here on FTE!!!!!!!
  #95 (permalink)
Old 10-25-2008, 12:15 PM
mattd17's Avatar
mattd17 mattd17 is offline
mattd17 is starting off with a positive reputation.
hey Ed..... do you (or anybody else) have a picture of p/n:7L3Z-19980-D?
i would like to see this climate controller before i drop the loot !!! also, i am wanting to change my mirror from power/non-heated/non-blinker to power/heated/blinker. are there any needed connections i will have to get to plug into the climate controller for the mirror defrost feature?
TIA !!
__________________
2006 F150 SCREW 4X4 5.4..... Magnaflow SISO, Edge Evolution Programmer, 6" RCD Lift, 1.5" lift shackles, 35" Pro-Comp Mud Terrains, ProComp 9047 wheels, Fire and Ice LED bar, Under hood engine lights, Glove box lamp, Dual style Fog/Driving lamps, Recon smoked cab lights, Putco LED dome lights, 6000K H.I.D. Headlights.... Who know's what next ??!!
  #96 (permalink)
Old 10-27-2008, 04:19 PM
FTE/PARTS-GUY FTE/PARTS-GUY is offline
ED NO LONGER WORKS HERE
FTE/PARTS-GUY has a great reputation on FTE. FTE/PARTS-GUY has a great reputation on FTE. FTE/PARTS-GUY has a great reputation on FTE. FTE/PARTS-GUY has a great reputation on FTE. FTE/PARTS-GUY has a great reputation on FTE.
TIA !!
i'm getting pictures taken of the control head right now, as soon as I get them i'll post the pic's.
ed
  #97 (permalink)
Old 10-27-2008, 04:57 PM
  #98 (permalink)
Old 10-30-2008, 07:36 PM
Well I got an A/C control head for my 2004 F150. I have the same issue witht he heated mirror light coming on with the button but then it goes right back out. Will my truck's wiring be ready for the heated mirror fuse block? And how much will the fuse box run me. Also I have a 2005 A/C control head I'd sell for $35.00 PLUS SHIPPING it works fine but it wouldn't work in my 2004 F150. I really want heated mirrors but I'll need a wiring diagram if I need to add all the wiring for them.
  #99 (permalink)
Old 10-30-2008, 08:22 PM
Ford Fx4's Avatar
Ford Fx4 Ford Fx4 is offline
Ford Fx4 is gaining momentum as a positive member of FTE.
Quote:
Yes, the wiring should be there you just need the new fuse block. I paid believe I paid around 136.00 for it.
__________________
2009 F-150 Fx4 SuperCrew 6.5' bed
Luxury Package-Navigation-Moon roof-Heated Leather Captions chairs-20's- Max Trailer tow
  #100 (permalink)
Old 10-31-2008, 05:25 PM
where did you get the fuse block for 136? The cheapest I've seen it for was 186.00.
  #101 (permalink)
Old 11-01-2008, 12:41 AM
Ford Fx4's Avatar
check your email
__________________
  #102 (permalink)
Old 04-02-2009, 06:37 PM
CHRISCRASH CHRISCRASH is offline
CHRISCRASH is starting off with a positive reputation.
F150 mirror
Quote:
Originally Posted by Ford Fx4 View Post
Got my mirrors today, got home from work and had two 35 pound boxes sitting on the step!
I will be putting them on tomorrow, hopefully I can get both trucks done......
Heres my parts list...
-6L3Z-19980-CA (heater control w/rear defrost button)
And of course the mirrors...
-7L3Z-17683-AE
-7L3Z-17682-AE
Hello. I had a question for you about the tow mirrors you purchase. I've been selling the ones you purchase on ebay. but I was told they fit 2007 to 2009. I get lots of questions regarding if the mirrors can fit 2004 to 2007. Did you have any problems with them properly fitting and is there wiring issues that have to be done? Look forward to hearing from you thanks
I notice you own a 2006.
  #103 (permalink)
Old 04-02-2009, 08:26 PM
Still Smoking's Avatar
Still Smoking Still Smoking is offline
2004 Ford F-150
Still Smoking is starting off with a positive reputation.
I got some on my 04. Just put them on saturday. The fit as the 04-08 are the same. Just 04-06 you need to change a couple wiring pins and the 07-08 you dont. Hope this helps
__________________
  #104 (permalink)
Old 04-03-2009, 04:48 PM
Ford tow mirror question
2004-2009 Ford f-150 TOWING MIRRORS W/ SIGNAL AND HEAT
CAN I REPLACE MANUAL MIRRORS WITH THIS ITEM AND IS THERE ANY OTHER PARTS REQUIRED TO DO SO
  #105 (permalink)
Old 04-03-2009, 04:49 PM
Quote:
Originally Posted by still smoking View Post
i got some on my 04. Just put them on saturday. The fit as the 04-08 are the same. Just 04-06 you need to change a couple wiring pins and the 07-08 you dont. Hope this helps
can i replace manual mirrors with this item and is there any other parts required to do so?
Tags
150 , 2000 , 20042008 , 2009 , f150 , f250 , ford , heat , mirror , mirrors , telescoping , tow , towing , trailer , wire , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
