Using the Cleveland 4v heads on a 400 - Ford Truck Enthusiasts Forums
Old 01-15-2002, 10:13 PM
Bull Bull is offline
Bull is starting off with a positive reputation.
After searching the message board, I found a company that makes port plates (which reduces the port sizes) for the 351C 4V heads. So I figure that a closed chamber 4V heads combined with the port plates may make a nice combo for the 400 short block. What I'm wondering is if the headers that I have for the 400 will bolt up to the 351C 4V heads. If not, what other choices do I have?
Old 01-16-2002, 10:46 AM
jimk351c jimk351c is offline
jimk351c is starting off with a positive reputation.
2v and 4v heads use different exhaust manifolds. The ports don't match up. You'll need headers specifically made for the 4v head.
-Jim
Old 01-16-2002, 04:40 PM
shazam shazam is offline
shazam is starting off with a positive reputation.
The Port spacing is the same just the size of the ports are bigger.
Old 01-17-2002, 01:35 AM
>bigger.
shazam, does it mean that it'll bolt up after all? Also, what kind of headers are you using on your monster?
Old 01-17-2002, 02:13 AM
blu93gt blu93gt is offline
blu93gt is starting off with a positive reputation.
you mean the thin platest - not the thick kind where you cut off the whole exhaust side of the head, right?
the headers will bolt up, but the header tubes will be smaller than the ports if you get headers made for 2v heads. i have the 4v heads, exhaust plates, and 1-7/8" headers. the plates match the heads pretty closely, and of course they close off the bottom part of the exh port in the head. but the header tubes are just barely big enough to match the plates on the tops & sides. looks like they could use some work with a dremel to match better. there WILL be a "step" at the edge of the plates, on the bottom of the runner. in other words, the plates do NOT make the 4v ports into 2v ports. the port shape and exit location are still different, even though they may be close to the same size.
has anybody dyno tested these plates on a 400 or larger motor?
Old 01-20-2002, 10:11 AM
Well on the motor I ran last year I had a set of 1969 Boss 302 Heads with the really big valves in them 2.250 int. 1.820 Exh. That motor ran really good an put out 658 H.P.
Now this Year I built my new Motor with a set of Boss 351C heads with the Exhaust port plates put on them with lots of porting done to them. These plates are the ones where they mill the heads and attach the plates that raise the ports 1" and really help them to breath.
Old 01-26-2002, 03:55 AM
GT40man GT40man is offline
GT40man is starting off with a positive reputation.
are they needed or helpful on a 400? has anyone ran them on a dyno?
Old 01-30-2002, 06:30 PM
As for what kinda headers do I use on ShaZam I built my own 2" Primary 37" equal lenght 3" collector wheelwell exit headers.
I started with a weld up kit from Stahl headers for the Big Block Chevy and they sent the flange plates for the 351C 4V Heads.Welded 2" stubs onto the flange plates and then started to hand fit the rest of the pieces together.
Custom Headers
Old 02-06-2002, 03:34 PM
snekrs_mach1 snekrs_mach1 is offline
snekrs_mach1 is starting off with a positive reputation.
Shazam,
I need to ask you a few questions.
Please reply to my Email: darryl.snedeker@fmr.com
Old 02-06-2002, 05:37 PM
beartracks's Avatar
beartracks beartracks is offline
beartracks is starting off with a positive reputation.
2v headers on 4v heads are going to give you reversion problems with the exhaust flow. Also 4v "quench" heads are (I believe) going to give you too much compression for street gas. Depends on what you want to do with it and how much modification you want to do.
You also need a four barrel intake (adapter plates) or you will get even worse problems on the intake side. Like maybe the intake wont even cover the head ports.
Bear Tracks
Old 02-06-2002, 06:43 PM
xyfalcon500 xyfalcon500 is offline
xyfalcon500 is starting off with a positive reputation.
[updated:LAST EDITED ON 06-Feb-02 AT 06:44 PM (EST)]Yeah, if you use the 400 2bbl intake on a 400 motor with 4v heads, you need to weld extra metal around the runners and have the intake mating surfaces milled flat afterwards.
Old 02-07-2002, 10:33 AM
stryder's Avatar
stryder stryder is offline
stryder has a good reputation on FTE.stryder has a good reputation on FTE.stryder has a good reputation on FTE.
Old 02-07-2002, 09:34 PM
i haveheard that none of the aftermarket 400 intakes are not that good
Old 02-08-2002, 07:48 AM
Well that could be on the 400 stuff the aftermarket is not all that good for just the 400's. I use all 351C stuff with adapter plates on my 400's. My latest intake is a Yates B351 NASCAR intake.
Old 02-08-2002, 11:34 AM
beartracks's Avatar
There ain't much choice for bolt on intakes for the 400. The edlebrock performer isn't too bad though, especially after port matching. I also like a 4 hole 1" spacer on it.
Bear Tracks
351C 2V Closed Chamber? nothercrash 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 28 03-19-2014 12:09 PM
351 C, 4V heads 0n 400, has anyone done? highp90town 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 5 12-15-2005 09:17 AM
4v Cleveland heads on 351m/400? How to make this engine better? the lotty 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 6 03-29-2004 09:48 PM
open chamber heads hellraiser 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 3 02-24-2003 01:00 PM
351C heads on 400M Billy Freeman 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 01-14-2003 04:23 PM
Tags
1978, 400, 400m, 4v, build, building, clevand, cleveland, engine, ford, headers, heads, motor, put, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
