My 02 Escape needs rotors and pads at 125K. As stated before the OEM rotors are soft and the pads are harder and that wears the rotors faster but you don't get the brake dust that cheap pads leave.
My 99 Sable has (for the most part) the same set-up as the Escape and I replaced the pad with ceramic and used slotted cyro rotors and have had very good luck out of them.
No or little dust, rotor wear, pad wear and have good stopping power.
At this point it looks like I will more than double the replacement interval between replacements.
The cost of the pads and rotors is more than OEM replacements but it looks as if I will come out better in the end with fewer changes and down time.
__________________
WV Chapter Member
2002 Escape (as fitter said "Wifes Ride")
1999 F250 4x4 SD Crew 7.3 "The Beast"
1999 Mercury Sable
1982 F250 4x4 Known as BullDog! wilh a 300 l6, Offy "C", Holley 390 CFM
1960 Austin Healy Sprite MK I (Bug-Eye)
