Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-05-2008, 08:23 PM
jethro b is starting off with a positive reputation.
early 95' E250 shift interlock issue?
On my 95 E250 it won't shift outta park when applying the brake. I have 2 questions?
1. Where exactly is shift interlock part? The Haynes manual was useless with zero pics.
2. Can this part be bypassed or removed?
Thanks in advance!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-06-2008, 03:44 PM
kynnhoj is starting off with a positive reputation.
I thought the shift interlock wasn't till later years, my '92 doesn't have it; my '98 does.
john
  #3 (permalink)
Old 03-06-2008, 06:03 PM
My early 95' did have it.
Solved the problem. The wire from the trailer hitch got pinched and grounded out the brake circuit. Replaced the fuse and re routed the wire and problem solved.
The van is being used by our Fire Dept. and someone hooked the tiedown strap in a hole but neglected to make sure no wires were underneath it before the strap was cinched down. I'll yell at them later. LOL
  #4 (permalink)
Old 03-06-2008, 07:25 PM
mhg mhg is offline
mhg is starting off with a positive reputation.
for future info the inter lock is on top of the steering column
down low near the brake pedal area
to disable it all that is needed is to unplug it
it is a small solenoid device with one wire
it is only energized when the key is on and
is turned off when the brake pedal is pushed
__________________
2003 bull 3.0 24v stock
1996 E-350 351
  #5 (permalink)
Old 03-06-2008, 09:11 PM
Cool, good to know for future needs. Thanks!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
